Is it shareware OS or the real deal? hehe.I know, that sucks... Thing is it cannot be anything I install, cause it happens straight after OS installation...
Yeah the Core i5 650 is limited to 150...lame.
@Jen, I can't get the old BIOS...they refuse to give it out.
As far as I can tell, all those CPUs work at the same voltages than "non-S" parts.This mobo support Cpu low power?
It still lights up like a Christmas tree for me when you turn the power on. When my board died it wouldn't even do more than flash an error number for a millisecond...but those lights were on!Btw Steeeeve, question regarding the dead DFI MI board, does the board still light up the way it should when you turn it on but no POST? just black screen? or there are no lights on it?
Yet when I set my memory to 1600Mhz in the BIOS the moment I hit F10 and select save the system will power off and refuse to post unless I clear the CMOS.
Same issue occurs if I select the memory's XMP profile.
Very weird behaviour. 1600mhz with this setup should be support right?
Have you updated to the latest BIOS? Should like 2/xx bios I think.Definitely something wonky with the USB on this board. I still get the occasional USB WLAN issue and problems with my Logitech DiNovo edge that have not been issues on other Win7 systems.
My config is:
P55-T36 w/ latest beta bios
i7 860
4gb Corsair XMS3 DDR3 1600MHz
yeah, I did it on the Core i5. Did you increase the RAM voltage at all?Yep, I installed the latest beta BIOS. The date for it is 2010-02-05. Have you been able to set yours to 1600 Steve?
Milas, when you say you cannot get the memory running at 1600 on your board do you mean that you were encountering the same result I was with the powering off the moment the settings are applied?
well chances are you won't be handling the board as much as I do to mess it up but for the people that replace heatsinks often or are a little less than careful it does matter. The supplied foam make it so you will have a harder time getting the backplate off. I think a lot of people opt not to have it. I If you do use the foam you still end up hitting the same piece but it's like having an airbag making it possible it doesn't rub as much depending on how much you tighten the screws. The foam on the other side will cover some mosfets which I think is not a wise move since you are basically insulating them if you do that. However it most likely won't hurt.
In any event, I haven't hurt reports of many people damaging their board other than me. One person already figured it out and cut down the backplate. Another said it is sitting on the piece but fine. Just an advisory; something to look out for. Thanks for the input, I'll add something about the foam.
Thoroughly pissed off. My USB Wifi has stopped working.
See www.sffclub.com advisory on this.Is it only my mobo, or did you find that backplate frame of that H50 doesnt align perfectly? Wehn I align all 4 holes of all triple-hole corners with mobo holes then the whole frame lays uneven....
Is that normal?
Ok after some months I can give the conclusion on this board
1. It overclocked is limited by it's PWMs, there are some voltera PWMs that i read could solve the issues, maybe digital PWMs too, would be a sweet rev. 2
2. There are the aforemetioned issues with the H50, that is due some mosfets on the underside
3. S3 sleep does not work at all If you overclock to 150BCLK or more. it goes to sleep just fine but will eventually get caught on a scary reboot loop. You've got to turn off the PSU to get out of the loop. Anandtech reported it but I haven't seen any workarounds. Now I use S4 hibernation because S1 does not turn of the GPU fans, it actually ramps them up to 100% so it's louder at sleep that off...duh
Otherwise a very good board, far better than my Intel DP55KG desktop board at the work.
Edit: it would be very helpful if someone could confirm the S3 issue please. I just upgraded to the latest BIOS beta and the issue persists.
I use the H50 too in a SG06, but didn't seem to have a problem, yet. I didn't screw down the bolts with a screwdriver, but rather with just a bit and my fingers, so that might have helped. I never tighten with screw drivers. You tend to over tighten with them.
I run an i750 at default voltages, didn't touch any of the mobo voltages, 160blk, and suspend works fine. My ram is set to 960mhz and undervolted to 1.4v. All power saving features for the CPU turned on. There's no performance differences that I can tell (I've had too many ddr2 dying at default voltages after just 1yr). I suspend it everynight, only rebooting for updates.
I do have a small fan blowing on the pwms though. In hwmonitor, the pwm temp is the 2nd number on the 2nd list, I believe. It should matchs up with the provided DFI app. At idle I get around 5c higher than the ambient temp reading, which if I remember correctly, is the number just below it. Load with prime95 I get ~70-80c.
The fancontrol in bios for the pwm is based on that reading. I think I have it set to 20/30/4, which seems to max the fan at around 60c.
I haven't totally finished with modding this mobo yet. I plan to take it back apart and cut some aluminum heatsinks to fit on the pwms. I remember there's 2 on the bottom as well.
Thanks for the feedback, as I said, the problem is with S3 suspend, not with hibernation or S1, but S1 is unusable due to the GPU fan ramping up.
You can verify that on the BIOS
I have a side fan too blowing at the PWMs and temps are not a real issue for me. The only real real problem is the S3 sleep issue.
S4 (hibernation) works as expected.
What memory speed? I can't select 1600Mhz unless I set BCLK to 1600MHz there si no divider or anything
what cpu coolers are people using with this? scythe big seems a safe bet?
What sort of ram clearence does it give (what fits? Ripjaws/dominators lol?)
Sorry! Really should have put some more info, looking at a lian li q08 when its out, and nothing untill then (open air)
Looking at the scythe big shuriken,
found some good ram too (gskill eco's so they will fit)
It'll be sat on a clocked i7 680 aswell. Next to a gtx 280.
227 - 86mm(psu) = 141 mm ish? Take out space for other side of the psu aswel, and motherboard... so guestimate 100 to 135
Althought looking at the pics on lianli's website, the psu sits flush to the top of the gfx card? Can't judge it.
