mrmylanman
- Jul 13, 2008
Decent amount. It's very tempting with the new Core i7s, etc., since it is very easy.
The i7 I have now is currently at 3.6GHz.
Well, the bottom line is that there is nothing wrong with this motherboard. If overclocking is more important than "small" than perhaps this isn't the board for you but for those that love small this is a dream come true.Decent amount. It's very tempting with the new Core i7s, etc., since it is very easy.
Not only would you be able to do this but you have to. The i7 is maxed at 150 bclk and stock voltages (board restriction that is).I was able to get my i7 up to 150 bclock on stock voltages, so if I could do that on this rig, I am sure it wouldn't hurt gaming much (at all). Throwing this and a 5850 or something inside a Lian Li PC-Q08 would be a very slick rig.
Ok so this board just might work for me because I plan on using Win XP, Now I just need to find a good usb wifi adapter that will work with a D-Link wireless router.From what I can tell the board isn't responsible for USB wifi issues...instead, Windows 7 is. Basically the lack of drivers is killing.
I've gotten a few reports from people that have Windows 7 64 bit who are using USB wifi. All of them said they are using devices that have a compatible driver.
DFI doesn't believe a problem exists as the USB code in BIOS is basically standard.
Yeah, it's a little tricky...I have a H50 and GeminII S both appear to be good...review coming in Mid-Feb on this comparisonthere's an article about a h50 / SG05 build at the corsair site here:
http://forum.corsair.com/upload/h50minipc.pdf
i have the h50 in my current mATX rig and i love it
I'm so tempted by this new DFI board to downsize again...
It's mini-itx! Have you seen the board!?i wanted to do this board and and i5 650 will max bclk be 180 if so toooo bad thats way to low.
Yeah, they do suck up some serious power over the 5770. The DFI board has about the same power consumption as a mATX board.Put the DFI on the kill-a-watt for a day and watched the numbers...
Idle: 96 watts
Web Browsing: 102-112 watts
Gaming: 145 watts, with spikes up to 172 watts when the action got heavy in COD:MW2
My last matx rig based on an XFX motherboard, e8400, XFX GTX 260 and dual V. Raptors idled at 112 watts, 330-350 watts gaming...
I have a hard time believing an SSD and a 5770 would make such a difference over two V. Raptors and a GTX 260 on the top end...
Liquid Cool
Idle: 96 watts
elpibe10...
Thanks for pointing this out. I had to clear my CMOS once and I forgot to reset a few items in BIOS. I did get it down to 84 watts at idle after changing fan management options to auto instead of - full on. Still hunting around to see if I can shave a few more...
I'm using a Corsair HX 520. It's been a pretty good PSU...very quiet.
Liquid Cool
Your board draw is normal...don't worry about itelpibe10...
I'm on 110 here in the States...
I went through the BIOS and made sure I had every setting exactly the way I think it should be set...I've been primarily using Intel(Bad Axe variants) motherboards for the last 4 years so I'm not used to extensive choices. Rather nice, especially on a small motherboard. I didn't expect much...
I'm happy with the wattage as it stands...I found 8 more watts in this product here that I plug my pc into...I didn't think it was taking up wattage and have never tested it. Once I plugged the pc directly into the wall, it was 76 watts. I have three of these, so I tested them all, they we're all drawing 8 watts. Interesting, I thought it was a passive unit.
<Click Here>
Coming from mostly full size pc's with multiple video cards to a short stint with an M-ATX set up, I now have a rig that burns up 150w or less and it's faster than I need for my use...not to mention, dead silent.
I'm all ,
Liquid Cool
I get people emailing me all the time about things and a number of them have overclocked with the 5850. I didn't have a 860 to test with but oh well. SilverStone has said the PSU is designed for it and since it is working for a number of folks I see no reason not to trust themNice review.
You say at the end of the article that the SG05/6's 300W PSU can handle this board and a 5850, but your test setup is with a 5770. Did you confirm that the PSU could handle, at full load, the DFI board and a 5850, or is that information second hand? I'm wondering if the PSU can handle an overclocked 860 to 150 bclk + 5850 card, without any instability whatsoever.
Haha, yeah...they sold so many they ran out..obviously.I have no comment until I can actually buy one!
.DFI told me it is selling better than they thought
It's hard to convince people that their $1.5k machine is not real world better than my $700 DFI mini-itx machine. Not everyone on these boards is a graphic designer.
That tells you how truly out of touch the current hardware sellers in the market are. Gone are the old days when it was acceptable for a PC to just be "another piece of furiture". Small is in, and it should be.
For most of the market ITX or DTX format is fine. Most casual users will have *at most* a vid card and a wireless card, although that wireless could be a USB dongle. At DTX case at least allows a dual slot vid card to plug into an ITX board.
For most everyone else, mATX is generally more than enough, even for dual vid card configurations. You have to be a hard core tinkerer or have very special needs to need more slots than what mATX provides.
I wish this board woudl have been available earlier. In october I travelled out of country and brought an matx i860 system in a cardboard box with me for work (no case).
That being said, the ITX/DTX format is still pretty weak for available cases and power supplies. Now you can get micro cases with very good airflow for very cheap (<$50). I really don't see that for ITX just yet.
New 1156 itx board by zotac
http://akiba-pc.watch.impress.co.jp/hotline/20100206/etc_zotac.html
