Hey all,
Its been a while since I last posted. A new job and probably a year later. Anyway I am building a new rig and I have come across a really big problem. The power will not come on.
At this point I have the PSU connected to the motherboard at both the 24pin and then the 12v rail securely. The motherboard has the memory fully seated to the motherboard. The CPU fan and CPU are both securely plugged into the mobo. Nothing else is plugged in. Attempts to start using the case's switch fail to start the power. I removed the mobo from the case and attempted to jump the power via screwdriver which also failed to work. The PSU is plugged in and the switches are in the correct positions. I swapped PSUs with a known working PSU, which also did not work.
Any help would be greatly appreciated.
Thanks!
Thanks!
