[NEW BUILD] Help and Assistance
Discussion in 'General Hardware' started by CharDar, Dec 9, 2018.
  1. jrweis
    jrweis Gawd
    562
    Sep 25, 2004
    You buy the key and download the ISO direct from Microsoft.
    Can burn a DVD or a USB stick using Microsoft's "Media Creation Tool"
  2. jrweis
    jrweis Gawd
    562
    Sep 25, 2004
  3. AthlonXP
    AthlonXP [H]ard as it Gets
    20,246
    Oct 14, 2001
    Sent you a PM, I have a machine that would fit your build and price range. You will end up getting a better deal this route versus building on your own.
  4. CharDar
    CharDar n00b
    38
    Mar 12, 2016
    Ok, great! Just looking to make a physical copy because I will need it when I purchase my rig!
  5. CharDar
    CharDar n00b
    38
    Mar 12, 2016
    Anyone know where i can get a cheap monitor?
  6. CharDar
    CharDar n00b
    38
    Mar 12, 2016
    Also, I just found out that I can upgrade my Windows 7 to Windows 10 for free! Does anyone know what version of Windows 10 it is?
  7. iwhocorrupts
    iwhocorrupts Limp Gawd
    168
    Dec 30, 2012
    My laptop upgraded to Win 10 Home.
  8. jrweis
    jrweis Gawd
    562
    Sep 25, 2004
    If You have Win 7 Home it will update to Win !0 Home, If You have Win 7 Pro or Ultimate it will update to Win 10 Pro. Also you should know that update is 32 bit to 32 bit & 64 bit to 64 bit, Can not do Win 7 32 bit to Win 10 64 bit!
    If your Win 7 is OEM you can not reuse it on your new build as it is locked to the hardware it was originally installed on. Must be retail version to reuse!
    "ickywu" gets $22 for Win 10 Pro SuperKey that you use with a download of the latest version (build: 1809) of Windows 10. Seems like a no-brainer to me to avoid all the hassle of going thru the Install 7-upgrade to 10-update 10 for hours1
  9. AP514
    AP514 Limp Gawd
    403
    Feb 15, 2006
    HAL_404 likes this.
