Hello guys; As you saw in the title, I want to build a new PC. The budget is around 3000€.
Right now I have an old overclocked Xeon x5675, which is consuming too much power for what it is capable to do. It is paired with a NZXT Kraken x61 AIO cooler(280mm radiator), and a GTX 1060 6gb for the graphics.
I'm looking for something that will hopefully last a lot of years, like my old system did. And just to put you in perspective of want I want, I'll tell you the procedure I followed when I bought the Intel CPU:
(WARNING: If you don't want to read "all my thoughts"(aka Wall of Text), go to the end of the post. From --MAIN-- onwards)
- I started with an i7-920 processor, which was good back then.
- I looked for a good Motherboard that would allow me to safely overclock the processors I could fit inside of it. Any quality-of-life features that further future-proof the system are welcome (In this case, It was USB 3.0. VERY helpfull down the line)
- Next step was RAM. I've always been a big fan of RAM, and so I went for a very good module at the time (12gb 2400 cl8 ddr3)
- Nice case with enough room for good airflow and future parts
- Good enough GPU to play games at monitor's frequency if possible.
This time I'm kind of doing the same, to hopefully achieve at least the same output.
But now I started with the monitor; I want a system that is able to deliver 240+ fps at 1080p in current and future competitive FPS games (overwatch, Quake...), and 144+ in games like PUBG. Which shouldn't be too difficult because my 10 years old system is capable of 135+ and 80+ w/o overclock. It should also be able to handle recording, streaming, video and 3D rendering.
Since I had no knowledge at all of the new technologies, I spent ~36hrs of the last weekend + 12hrs of this week looking for info. I went over:
-TR4 -> Not worth. Short life and bad in games.
-Intel X299 -> Really good until I saw the power consumption of the new 10xxx processors under load. It also seems to be at the end of its life cycle, hindering longevity. So it fails two of my main concerns.
-AM4(x570) -> Looking VERY good atm.
-TRX40 -> Looking exceptional(ly expensive) atm.
AMD seems to be the better choice. x570 and TRX40 are recent, so I guess they will give it support until DDR5 RAM in 2021 or so. Allowing me to upgrade in the distant future and, therefore, increasing longevity. PCIe 4.0 comes in handy as well (even tho I saw some peopple mocking it), it's kind of the same situation as with USB 3.0; you don't want to be stuck with lower storage speeds 6-8 years from now, it also opens up the possibility of faster GPU speeds in the future I guess. So I actually value that.
The PC will be bought mid January to early February, depending on prices and christmas expenses. This is what I came up with so far (Not finished yet, just an idea):
AM4(x570) Build:
Monitor: 240hz panel. TBA. 500€.
RAM: 4x8gb G.Skill NEO 3800 cl14. 615€
CPU: R7 3700x. 345€
MOBO: TBA. 450€¿?
GPU: RTX2080ti. 1200€
PSU: TBA. 180€
Case: NOX Hummer. 43€
Cooler: NZXT Kraken x61. 0€
SSD: 0€
Total: ~3333€
TRX40 Build:
CPU: TR 3960x. 1500€
MOBO: TBA. 500€¿?
GPU: GTX 1060 6gb. 0€
PSU: TBA. 200€¿?
SSD: 0€
Total: 3358€
The x570 build is more well-rounded I feel. Fits my needs right now and allows me to upgrade to, at least, a R9 3950x processor in the future (probably even newer ones launched in 2020). Looks pretty much like my old x58 build, nice and solid. I chose the RTX2080ti because I feel it will retain the value better once the 30 series hit the market in 2020. Main concerns are low PCIe lane count and dual-channel memory (longevity, quality-of-life features).
The TRX40 build is weirder, but more exciting and with more potential I think. It greatly surpasses my needs right now, which means I wont have to upgrade until very very late. And in case I need an upgrade, I have the 3970x and whatever comes in 2020. I could also double the RAM by buying another kit (even tho it will be next to impossible to find the same model). Main concerns are power consumption and cooling, as well as the "fear" that the platform (since it is the HEDT platform) will only "grow horizontally" instead of "vertically" as well (meaning adding more cores without considering high frequencies/single core performance too much).
The only caveat (that I know) of the TRX40 build is the fact that I can't afford a new GPU, but the GTX1060 is capable of achieve 180fps (overwatch) when I play with my old Xeon at 4.45ghz. I don't think the 1060 can achieve 240fps even if I overclock it, but paired with the new monitor it would be a big jump in enjoyment anyways. Aaaand with the new 30 series of Nvidia, I could probably get another cheap 1060 and achieve the wished 240hz for a few Euros, thanks to the many PCIe lanes that TRX40 offers(that will also greatly help with storage), and upgrade to a better GPU later.
----------------MAIN-------------------
So, I need you guys to guide me. I need help.
The monitor is non-negotiable, it will be bought (benq XL2546 most likely).
I said that I'm a big fan of RAM, specially in a Zen system, and that's why the 3800 cl14. If you can give really solid arguments of why it's a waste of money (or find one that is better and fits in the budget), it could be dropped from the list; otherwise it is pretty much non-negotiable also. All the other parts are susceptible to change (except the processor+GPU in the TRX40 build, of course). For each build, I'm specially interested in:
-MOBO with quality "acomodations" for the RAM, that is also able to handle some degree of CPU OC as well.
-A PSU that feeds what needs to be feeded.
So, given the next two builds, complete the missing items. Try to stay as close to the budget(3000€) as possible:
Build 1 - AM4(x570)
CPU:
MOBO:
GPU:
PSU:
Case:
SSD: 0€
Total: 1115 + ??? = ???€/$
Build 2 - TRX40
MOBO:
PSU:
Case:
SSD: 0€
Total: 2615 + ??? = ???€/$
Thanks to all.
Pd: Special thanks to the ones that took the time to read all the post.
AM4(x570) Build:
CPU: R7 3700x. 345€
MOBO: TBA. 450€¿?
PSU: TBA. 180€
SSD: 0€
Total: ~3333€
TRX40 Build:
MOBO: TBA. 500€¿?
PSU: TBA. 200€¿?
SSD: 0€
Total: 3358€
Build 1 - AM4(x570)
CPU:
MOBO:
GPU:
PSU:
Case:
SSD: 0€
Build 2 - TRX40
MOBO:
PSU:
Case:
SSD: 0€
Thanks to all.
