I just finished building the system for a friend of mine, and when I turn it on it doesn't display anything on the monitor.
The specs are:
Mobo: Gigabyte GA-P55-UD3P
CPU: i5-760
Vid Card: EVGA GTX-460 Fermi
HDD: Velociraptor 150GB
PSU: Corsair 650TX
Fan/Heatsink: Cooler Master Vortex Plus
At first I noticed that when I turned on the computer the CPU Fan moved to start to spin but would just stop. So I plugged it into one of the ports for a system fan, booted and the fan spun fine, but no display on the monitor. I checked the video card, reseated it made sure the 6-pin connectors were both on properly, booted the system and still no display. So I took the card out, and put in an older card from another machine that I know works, booted the system and still nothing on the monitor, it just goes into standby. Now funny thing about the CPU_Fan port on the mobo is that if I connect any regular 3-pin fan it'll power the fan without a problem, but when connecting the 4-pin CPU fan that that's supposed to go there it wont spin.
I dont know what it could be honestly, could it be the PCI-Ex16 port on the mobo came defective?
The specs are:
CPU: i5-760
PSU: Corsair 650TX
