thenewrick
- Oct 7, 2009
I think I read somewhere that they were using up the good 5870s for 5970s and that the retail 5870s now, or soon, will be lower quality?
So we're thinking the 5850 is the best sub $300 card for the next 3 months?
Got a link?I think I read somewhere that they were using up the good 5870s for 5970s and that the retail 5870s now, or soon, will be lower quality?
People have already been complaining about 5970s downclocking. Since a 5970 is down clocked to a 5850...not sure if they even have to bin the chips.
I think what the OP means is that AMD are cherry picking the 40nm cores so the ones with bigger overclocking potential go to the 5970 cards.
This does not effect the stock quality of the 5870s, all the cores are tested to work before the cards ship, all it effects is the potential overclocking headroom of the 5870s.
The reason the 5970 has cherrypicked cores is because the card is marketed as an overclockers card, the card comes with cooling which is designed to handle way more thermal output than what the card produces at stock, it also has high quality voltage regulators and comes with overvolt tools to allow you to overvolt the card and increase overclocking headroom.
The 5970 is basically 5870 hardware downclockde to 5850 speeds, the reason they did this was to keep inside the 300W limit as defined in the PCI-e2.0 specifications. Most 5970s have no issue reaching the same kind of overclocking speeds the 5870s reach, 1Ghz+ on the core, 5100-5200 on the memory.
No vapor chamber/heat sink contact on the second set of vrm limit OC potential on the 5970. Although I see people getting their core clocks up pretty high with these cards.
Waterblocks were invented for a reason
