New and Improved Watercooling Sticky - Post Your Systems Here
Discussion in 'Water Cooling' started by zer0signal667, Jun 1, 2004.
  1. w1retap
    w1retap [H]ardForum Junkie
    11,770
    Jul 17, 2006
    Couple more shots..
    [​IMG]
    [​IMG]
    [​IMG]
  2. prasvt
    prasvt Gawd
    554
    Dec 8, 2005
    Here's my first attempt at water cooling. Swiftech H20-220-APEX-GT kit. Good kit, though my only complaint was that the plastic clamps are utter crap - ended up having to improvise and use nylon zip ties. On the upside, the tubes fit nice and tight on the barbs (had to use boiling water for all of 'em pretty much). Also, I had to move the top radiator fan to the outside b/c it was interfering with the PSU plug. It's an active psu so it's getting the push + pull treatment.
    Anyway the loop only includes the CPU. Here are some pics.
    [​IMG]
    [​IMG]
    [​IMG]
    [​IMG]
    [​IMG]
  3. v3rt1g0
    v3rt1g0 [H]ard|Gawd
    1,149
    Aug 20, 2002
    Just a bit of a teaser while I write up the project log.. and some picture galleries further below.
    I'm finishing up the top panel now, then I'll button the whole thing up.
    [​IMG]
    Early Stage Picture Gallery:
    http://www.mikebarr.net/pictures/projects/box_upgrade_06_2008/index.html
    Later Stage Picture Gallery:
    http://www.mikebarr.net/pictures/projects/box_upgrade_06_2008_2/index.html
    Parts List:
    - Lian Li PC-A70B Aluminum Case
    - ASUS Maximus Extreme X38 Mobo w/Built-in Chipset Waterblock
    - Intel Q9300 2.5ghz Core2Quad w/DangerDen MC-TDX Waterblock
    - OCZ Plat 4GB (2GBx2) DDR3 1600 (PC3 12800)
    - Two 150GB WD Raptors (RAID0) w/AlphaCool SilentStar Dual HDD Waterblock/Silencing Box (w/Additional layers of mousepad for sound dampening)
    - 8800GTX w/DangerDen 8800GTX Waterblock (GPU is ~1yr old, Waterblock is new)
    - Two random automotive heatercores w/added 1/2" hose barbs and shrouded 140mm YL fans
    - Lots of 1/2" ID 5/8" OD Tygon tubing w/coolsleves, couple dozen 5/8" hose clamps, Mousepads, etc.
    - Enermax Liberty 620w PSU w/All wires stealthed
    - AquaXtreme 50Z-DC12 Pump w/Custom suspension framework
    - Sunbeam Rheobus w/Stealth Faceplate, same for DVDRW
    Going to start OC'ing the beast this weekend..
  4. Mick64
    Mick64 n00b
    26
    May 4, 2008
  5. Down8
    Down8 2[H]4U
    3,049
    Sep 21, 2003
    [​IMG] [​IMG]
    Li'Lfish, DX38BT, Q6700@3.33GHz, 2GB Crucial Ballistix DDR3, WD6400AAKS, HD4850 (needs an S1), Lite-On SATA, HX620
    MCR-220+Yate-Loons, MCP-655 @ 1, DD X38, DTek Fuzion V2+Quad, microsres, 7/16" MasterKleer, PrimoChill UV coils
    [​IMG] [​IMG]
    PSU is weatherstripped to isolate from the inside (air drawn from outside goes right back out)
    Rad is weatherstripped to force the hot air down through vent holes
    80-120m adapter on another Yate-Loon forces the intake air towards the rad intake (temporary until I make a better duct)
    [​IMG]
    Temporary 120mm until I get Kama-bay or Lian-Li bay,
    and the older style 80mm Li-Li bay for my HDD(s)
    I have a small concern that the res is too low, and I definitely need taller feet/Li-Li replacement wheels to remove some restriction on the rad exhaust. But, so far it's working great. I haven't been able to get it above 56*C (even at 87*F ambient), but I still need a fan controller to lower the noise.
    I just figured out where to put this:
    [​IMG]
    :D BoneTrail FTW!
    [​IMG] [​IMG]
    Lastly, I call these shots "Confessions of a Hardware Junkie":
    [​IMG] [​IMG]
    I'll need to take these again when I clean up the HTPC, and I'll open my laptop & lay out the Axim just to make the family complete. :D
    (The SonataIII is actually empty - for a few more days - it's going to be a sound editing machine for my brother-in-law.)
    Also, I'm finally 2[H]4U, sweet!
  6. Mick64
    Mick64 n00b
    26
    May 4, 2008
    Yesturday, I replaced my DDC pump with a D5 and mounted it in the bottom section. Added a bit of sound proofing as well to tidy things up.:D
    [​IMG]
    [​IMG]
    [​IMG]
    [​IMG]
    [​IMG]
    [​IMG]
    [​IMG]
    [​IMG]
    [​IMG]
    [​IMG]
  7. LiQuiD[EViL]
    LiQuiD[EViL] Limp Gawd
    181
    Jul 1, 2003
    1st WC setup. Any comments, especially how the tubing is routed, would be great.
    [​IMG]
    [​IMG]
    [​IMG]
    [​IMG]
    [​IMG]
  8. MrE
    MrE 2[H]4U
    2,409
    Jun 19, 2004
  9. Vlad_13
    Vlad_13 [H]ard|Gawd
    1,825
    Jun 22, 2006
    Update! Got new ram and video card :D
    [​IMG]
    [​IMG]
    [​IMG]
    And here is the red girl :D Idles around 38-40C Load temps 42-45C
    [​IMG]
  10. Stabbin
    Stabbin Limp Gawd
    141
    Jun 2, 2006
    My Wolfdale rig:
    [​IMG]
    [​IMG]
    ~S~:)
  11. mode
    mode n00b
    29
    Nov 24, 2007
    My first WC build
    Before:
    [​IMG]
    After:
    [​IMG]
    [​IMG]
    [​IMG]
    [​IMG]
    [​IMG]
  12. mit78
    mit78 Limp Gawd
    383
    Nov 8, 2006
    my final rig now.
    [​IMG]
    [​IMG]
  13. R1ckCa1n
    R1ckCa1n [H]ardness Supreme
    4,378
    Jul 22, 2004
    My newest build based on some good Feser gear.
    Out with the OLD:
    [​IMG]
    The goods:
    [​IMG]
    In with the NEW!
    [​IMG]
    [​IMG]
    [​IMG]
    [​IMG]
    [​IMG]
    [​IMG]
    [​IMG]
    Last, some temps.
    [​IMG]
    [​IMG]
    [​IMG]
  14. swale
    swale Limp Gawd
    274
    Feb 3, 2008
    Ok some nice rigs on here, some photos of mine below....
    [​IMG]
    [​IMG]
    [​IMG]
  15. JLangevin
    JLangevin [H]ard|Gawd
    1,181
    Apr 13, 2007
    Watercooling items:
    -1/2 ID Tube
    -Older Swiftech Waterblock
    -FluidXP non-conductive coolant
    -Dangerden Micro-Pump (super quiet)
    -Swiftech Reservior
    -120mm x 2 Radiator Mounted on top of case.
    [​IMG]
    [​IMG]
    [​IMG]
  16. Mick64
    Mick64 n00b
    26
    May 4, 2008
  17. AntiHeroUK
    AntiHeroUK n00b
    20
    Jun 4, 2008
    My first attempt at water cooling :)
    [​IMG]
    [​IMG]
    [​IMG]
    [​IMG]
    [​IMG]
  18. grugar
    grugar n00b
    42
    Jun 17, 2004
    [​IMG]
    nearly finished.
    clear water was boring, so i decided to make it blue!
  19. mellojoe
    mellojoe Gawd
    704
    Mar 19, 2007
    This project has been an EXTREMELY long time coming. 3 years, stalled out multiple times due to some medical problems my wife has had to endure, but with her clean bill of health came a new enthusiasm to complete this project.
    This weekend, I finally did it.
    [​IMG]
    [​IMG][
    You can see the second radiator in this photo:
    [​IMG]
    Intel E7200 @ 3.8 ghz
    VCore @ 1.36v
    DTek Fuzion v2
    2 x 120mm BIX GTX II
    Swiftech MCP655
    Swiftech MicroRes
    1/2" Barbs
    7/16" MasterKleer
    clear PrimoChill Liquid Utopia
    clear Distilled Water
    black Anti-Kink Coils
    All tucked nice an neat inside my black Lian Li PC A16. :):D
    [​IMG]
    This is where we started:
    [​IMG]
    [​IMG]
    PS: One of these days I'll set it up on a table somewhere so I can take some really good shots of it. I want to setup a mini photo-shoot and try to get some good pictures. Black on black is hard to shoot.
  20. carholmes
    carholmes n00b
    47
    Dec 2, 2006
  21. Stabbin
    Stabbin Limp Gawd
    141
    Jun 2, 2006
    Added a second 8800gts for some sli action. I know its behind the times but it still can twist some gaming arms. E8400@3.6.;)
    [​IMG]
  22. MrE
    MrE 2[H]4U
    2,409
    Jun 19, 2004
    Updated the loop. New DDC 3.2 converted from an Apogee combo block
    [​IMG]
    I need a new camera. :(
    [​IMG]
    [​IMG]
    [​IMG]
  23. TURNnBURN
    TURNnBURN n00b
    32
    Oct 5, 2008
  24. swale
    swale Limp Gawd
    274
    Feb 3, 2008
    Heres my new and updated rig....
    [​IMG]
    [​IMG]
    [​IMG]
    [​IMG]
  25. bonghitter400
    bonghitter400 [H]Lite
    75
    Apr 5, 2007
  26. AntiHeroUK
    AntiHeroUK n00b
    20
    Jun 4, 2008
  27. ontariotl
    ontariotl Limp Gawd
    247
    Oct 2, 2008
    Now that I finally got around to tidying my own rig up, I thought I would post some pics. Not as fancy as many on here, but I'm happy with the results
    [​IMG]
    [​IMG]
    [​IMG]
    [​IMG]
    [​IMG]
    [​IMG]
  28. heatsinker
    heatsinker [H]ardness Supreme
    5,441
    Feb 4, 2001
    Definitely not the slickest setup in this thread, but this is my first attempt at water cooling. :D
    I was actually planning to back mount the radiator since it was popular opinion that the Feser 360 had 17mm spacing, but mine came with 15mm spacing which matched the fan holes on top of the HAF perfectly.
    [​IMG]
    [​IMG]
    [​IMG]
    [​IMG]
  29. TI66ER
    TI66ER Limp Gawd
    135
    Aug 29, 2006
    Heres mine-
    [​IMG]
    [​IMG]
    [​IMG]
    [​IMG]
    [​IMG]
    [​IMG]
    Specs
    Processor: intel c2d E6750 @ 4ghz 1.5625vcore
    Motherboard: asus pq-e bios 1201
    Cooling: wATER
    Memory: 2x1gb Crucial ballistix pc8500@1000 1:1 5.5.5.15 2.0v
    Video Card: Gainward 4850 with xspc RAZOR waterblock
    Harddisk: 2x250gb samsung spinpoint sp2504c
    CD/DVD Drive: samsung SH-S183L sata
    CRT/LCD Model: LG l194ws widescreen lcd
    Case: Lian li V1000B plus II
    Sound Card: Onboard sound digital out to av amp
    PSU: Corsair hx520w modular
    Software: windows vista home premium(real)
    Loop is-
    Swiftech Apogee gt
    Swiftech ddc3.2+xspc top
    Xspc Razor full cover 4850 block
    Black ice pro 240mm radiator
  30. Deimos
    Deimos Gawd
    922
    Aug 10, 2004
    Build log is over in the case mod gallery section, here is my latest build (Project Phobos):
    Lapped the water blocks and CPU, I didn't take any photos, only the end result of the CPU and CPU water block.
    [​IMG]
    [​IMG]
    I decided to change the colour of my liquid, so got Feiser One in blue, and changed all the tubing to Tygon 1/2" ID.
    [​IMG]
    Might as well upgrade the ram while I'm at it, got myself 8GB of Corsair dominator.
    You can't really see it here but I shifted the Zalman heatsinks from the ram on the video card to the mosfets and installed Swiftec heatsinks on the ram
    [​IMG]
    Mounted the UV lights properly (no more hotglue) and here it is all lit up.
    [​IMG]
    [​IMG]
    And finally, my poor old window was looking pretty beat up, so using the polishing kit I bought to lap the CPU and water blocks, I polished up the window, finishing off with car polish to get rid of the light haze left in the process.
    [​IMG]
    Specs are:
    Silverstone Strider 850W Modular
    Swiftech Apex Ultra plus water cooling
    Darkrider case
    Core 2 Quad Q6600 @ 3.48Ghz 435 FSB x 8 Vcore 1.456v, CPUPLL 1.55v
    Asus Maximus II Formula
    AMD-ATI Radeon 4870 @ 790Mhz core, 1100Mhz Memory
    2 X Western Digital RE 500Gb SATA2 16MB Buffer RAID 0
    Corsair Dominator 8GB PC8500 1066Mhz @ 5-5-5-12 1096Mhz 2.3v
  31. K1tty
    K1tty [H]ard|Gawd
    1,962
    Mar 11, 2006
    "Back in the day" build AMD X2 and SLi 7800GTX's
    [​IMG]
    [​IMG]
    "Way back in the day" build - custom server case and water cooling
    [​IMG]
    Most recent h20 build from last year: QX9650 and 8800GTX
    [​IMG]
    [​IMG]
    Current build pics coming soon .... but it isn't h20 :)
  32. Justphilbo
    Justphilbo n00b
    4
    Oct 21, 2008
    I have everything pretty much done on this rig.
    It is a MM U2-UFO Horizon case with a C2D E8400 @ 4.230, 2x 4870x2 @ 800/950, 4 gigs of SuperTalent DDR3 1800 and a Soundblaster X-Fi Extreme Gamer on a Gigabyte GA-X48T-DQ6. Drives are a 500 gig WD and a Samsung DVD burner, both SATA II.
    CPU loop is a Alphacool Laing DDC Ultra pump/res, Alphacool NexXxos XP block and a MCR220QP radiator.
    GPU loop uses the same pump, two EK FC4870x2 blocks and a MCR320QP Radiator. Hoses and fittings are 3/8" and the fluid is PrimoChill Black/UV Blue.
    Almost all case hardware is 18/8 stainless #6-32 SHCS (allen) with stainless washers.
    The picture from the soundcard side shows the MB bowing down a bit, but I have fixed that.
    Also, not pictured is the top, which is clear Plexi.
    Side panels are cut down screens from Home Depot, painted gloss black to better match the case.
    Thoughts and comments appreciated.
    [​IMG]
    [​IMG]
    [​IMG]
    [​IMG]
    [​IMG]
    [​IMG]
    [​IMG]
    [​IMG]
    [​IMG]
  33. thaddeus.cto
    thaddeus.cto Gawd
    676
    Nov 16, 2007
  34. utnorris
    utnorris [H]ard|Gawd
    1,204
    May 18, 2008
    Here is my rebuild of my MM UF2O with the new Pedestal, the pics are not the best, but you get the idea:
    [​IMG][/IMG]
    [​IMG]
    By utnorris, shot with Canon PowerShot A540 at 2008-11-03
    [​IMG]
    By utnorris, shot with Canon PowerShot A540 at 2008-11-04
    [​IMG] By utnorris, shot with Canon PowerShot A540 at 2008-11-03[/IMG]
    [​IMG]
    [​IMG]
    [​IMG]
    [​IMG]
    [​IMG]
  35. durazor
    durazor n00b
    1
    Nov 1, 2008
  36. soup666
    soup666 [H]Lite
    94
    Nov 12, 2008
  37. crazyfinx
    crazyfinx Gawd
    570
    Nov 14, 2006
    here something I put together this weekend, still have to finish the mounts for the pumps and also wanted to add some blue LED's around the case to finish up - let me know what you guys think :D
    Lian Li V2010
    Win Vista x64
    DFI LT P35
    e8400 @ 4.03ghz
    4gb DDR2 Geil Estoria 800
    ATI 4850
    3x 320GB 16mb 7200.10s RAID 0
    3x 500GB 32mb 7200.11's RAID 5
    1X 37GB Raptor
    [​IMG]
    [​IMG]
    [​IMG]
    [​IMG]
    [​IMG]
    [​IMG]
  38. doox00
    doox00 2[H]4U
    2,891
    Aug 28, 2005
    Just completed mine last night.
    [​IMG]
    [​IMG]
    [​IMG]
    [​IMG]
    [​IMG]
    [​IMG]
    [​IMG]
  39. prasvt
    prasvt Gawd
    554
    Dec 8, 2005
    Well here's my new build. After my Abit iP35 Pro went down, I picked up an Asus Maximus II Formula and a Cosmos S case so I could keep the radiator inside the case. So here are a couple of pics. Only the CPU is watercooled as the GTX260 Core16 runs pretty cool on its own.
    So the MCR320 radiator fit perfectly inside the ceiling of the case with just enough room to clear the motherboard - I'm using three fat 120x38mm fans (2 scythe, 1 panaflo). Reservoir and Pump were mounted in the 5.25" bay above my 2 optical drives - using velcro to secure them.
    [​IMG]
    Just a shot of the roof fans - 3 Coolermaster 1200rpm quite fans (blue LED).
    [​IMG]
    Everything connected. I tried to do do a little better cable management and it's pretty clean for the most part.
    [​IMG]
    Just a shot of it running. Have a Sunbeam fan controller controlling the rad fans and the roof fans.
    [​IMG]
    Thus far, even with the radiator inside the case (as opposed to mounting on the back as before), the temps are as good if not better. Has been idling @ ~31C and high 40s under load @ 400x9..but I've only done rudimentary overclocking..
  40. MrE
    MrE 2[H]4U
    2,409
    Jun 19, 2004
    Swapped from a single to a dual loop:
    Before:
    [​IMG]
    After:
    [​IMG]
    [​IMG]
    [​IMG]
