@jdk, what tubing is that? or is it some sort of sleeve?
I was just quoting "wingless92", that's his case..
So @wingless92, what kind of tubing are you using? I must admit the matte black looks slick
Keep waiting... I doubt you'll ever see waterblocks for MSI custom designs, just like you never see waterblocks for MSI motherboards.
GPU 0 - NVIDIA GeForce series (10de-1087) - GPU clock: 1000 MHz - Mem clock: 1950 MHz - Max GPU temp: 34 °C - Max GPU load: 99 %
Nice job Sonda5.
Now for my 2150 RPM Gentle Typhoons to come on...
has to be the best ghetto mod on a card i've seen.....beats teh H50 on nvidia cards by a mile.
Thanks. That ported Apogee XT is working fantastic.
I'm thinking about selling off all my fans and ordering 8 120mmx25mm 4200 RPM gentle typhoon fans. Only thing is I will have to upgrade my 4 channel fan controller to handle the amperage of each channel. I will probably do this. Had I known about these fans from day 1 I would have ordered them to save money on over all costs. Just waiting for a good reason to upgrade of a super hot deal on the fans that I want. I am definitely going to upgrade my fan controller soon. My current Scythe 4x1 amp per channel controller may be running a little close to its limits. Thinking about getting a 30 watt per channel to pump up the power of each channel to give my current fans plenty of room to breath during high system voltage over clocking.
One thing to remember Sonda, is that even with a fan controller running AP-30's at 5v, they are louder than AP-15's at full speed. They also push less cfm/rpm because of the stabilizing ring.
Over all CFM at max RPMs is greater though. My stealth BI radiators are designed to work best with high RPM/CFM fans.
I like quiet but when I need maximum cool I want to have it available.
^^^ Nice setup. 2 quick questions
1) Was there a reason you moved the pump?
2) Do you have any issues with air in your loop with your reservoir at the bottom of your case and the rad up top?
Thanks for the compliment
1. I went from a HAF-922 Mid Tower case to an NZXT Switch 810 Full tower and didnt have any spare tube. The tube was not long enough to reach the bottom of the case so I velcroed the pump to the PSU. I bought new hose yesterday and may rearrange the loop.
2. No air is in my system. It actually bleeds really fast. You cant really see it, but the res is not actually at the bottom of the case, it is mounted to the rear side wall of the case and is even with the pump. I should have taken a better pic of that. I will update the images later when I get home (and redo the loop) of where the res is mounted.
Looks good JLangevin. Very clean.
Though I got to ask you one question, why'd you go with the TR2 RX? Probably one of the crappiest PSUs next to those unknown Chinese brands.
what size tubes are those? also is that gfx card tilting without that black pole for suupport?
I want to post some pics of my rig but I am having trouble figuring out how to upload the pics.
