New and Improved Watercooling Sticky - Post Your Systems Here
Mayhems Ultra Deep Blue dye from WCDYES.COM
For the love of god, don't ruin your loop with dye.
Everyone who has used dye comes back posting that it was the worst idea ever. Take it from someone who tried four dyes from four companies and ended up with hours of scrubbing every single block i own.
agreed 100%. just get some colored tubing instead. dyes are more trouble than theyre worth.
added two more fans for a push/pull config. They're SilenX 11dB 120s (all 4). Also reversed the fan direction to keep the GPUs cooler. Even the air being warmer from going through the rad, it will keep the GPUs cooler than just sitting there with no air movement at all. Dropped another 5C @ 100% load. Running 65C now. GPU idle temps are down 12-15C across the board with fans reversed from yesterday, as well.
thanks guys, but I like to not learn the easy way.
CPU- AMD Phenom II X6 1090T O/C Freq : 4192.59 MHz (215 * 19.5)
RAM- 4GB PC-10700 Patriot Viper Xtreme O/C 860 MHz (1:4) @ 8-9-8-24
MOBO- MSI 890FXA-GD70
GPU- XFX HD Radeon 6950 1GB
SSH/HDD &
Raid Controller-
2x Seagate Momentus XT 500GB total SSH (hybrid)\\RAID 0 config for O/S, Programs & Games
2x Hitachi 500GB total HDD\\RAID 0 config for media storage
Vantec 6-port SATA II 150 PCI host card (ugt-st310r)
TOWER- Corsair 600T (graphite series)
Power Supply- OCZ ModXstream-pro 700W
COOLING SOLUTION- Custom W/C setup consisting of the following components:
Pump- Swiftech MCP355 12VDC
Res- Phobya Balancer/150mm - Black Nickel
Radiator- Swiftech MCR220 Quiet Power Series 120mm
CPU WB- Danger Den MC-TDX multi core
Tubing- Feser 3/8" ID (1/2"OD) - UV Blue
Barbs/compression fittings/clamps/accesories:
2x Swiftech BSPP-250-375-CP 3/8" chrome barb fittings
2x Alphacool 13/10 (10x1.5mm) Compression Fitting 45° Revolvable G1/4 - Deep Black
2xAlphacool 13/10 (10x1.5mm) Compression Fitting G1/4 - Deep Black
Reuseable Clamps - For 1/2" O.D. Tubing
Anti-Kinking Spring 13mm
Fans- 3x Cooler Master 120mm/2000rpm, 1x el cheapo/generic (need to replace) 200mm intake fan in front of case
I think that's everything for now.... I may however add an additional GPU (crossfire) and watercool that mofo :thumbsup​
whipped this number up a few months ago for a client. pics aren't great buy you get the gist. x6 1100t at a humble 4ghz.
not sure if this image will work, I'm too lazy to upload to photobucket at the moment.
I suck at cable management. I really need to get some patience.
A water cooled emachine tower circa ~2003 I have wanted to W/C it for ever, only just now had the right tools/means. This is a million times quieter than the stock amd fan.
now every PC in my house is water cooled.
and from this
to this
This is a build I did for a customer, just wanted to share :)
2600k, Z68-UD7, XFX HD 6970, 16GB Kingston Hyper X
2x OCZ Vertex 3 120GB SSD's Raid 0, 2TB HDD
EK Supreme Full Copper
Heat Killer 69X0 Waterblock
RX360, MCP 355, XSPC Dual Bay DDC res, 6x GT's.
I would have liked to do some color tubing, but they didn't want it :/. I think purple or something would have offset the 800D and the mobo pretty nicely.
IMG_1094 by AdvanSuperDuper, on Flickr
IMG_1108 by AdvanSuperDuper, on Flickr
IMG_1112 by AdvanSuperDuper, on Flickr
IMG_1114 by AdvanSuperDuper, on Flickr
IMG_1120 by AdvanSuperDuper, on Flickr
IMG_1122 by AdvanSuperDuper, on Flickr
IMG_1136 by AdvanSuperDuper, on Flickr
IMG_1138 by AdvanSuperDuper, on Flickr
IMG_1110 by AdvanSuperDuper, on Flickr
IMG_1098 by AdvanSuperDuper, on Flickr
IMG_1088 by AdvanSuperDuper, on Flickr
My brothers computer.
My older comp from 3 years ago.
I will post my current computer within the net few days since im doing a total remodel to the case and the cooling system. will post before and after pictures
Mother of God, what have you done to that V2000B? :p
See below for why you throw away the tubing that comes with XSPC kits, it turns amber with age.
Hes not really joking... he just doesn't want to get a warning for thread crapping...
That picture...is ...interesting... I look forward to the final and hopefully improved setup...
Here is one of mine...
messing around with some old gear + a used DFI x48 mobo I bought... the cooler is a modded Nautilus 500 with a black ice extreme rad and aerocool fan... trusty ol mc tdx and e6850 underneath.. going to see how far I can push this cpu on the dfi board. should be interesting.
New build for a buddy of mine. 2600k @ 4.6Ghz, 16GB DDR3, Asus P8P67 LGA, MSI GTX 570 (800/2000), 2 x Samsung F3s in Raid 0, Blu Ray Burner.
This is my new build in a brandnew TJ08-E small and clean with (high-end) external cooling.
Hardware used
Asus Rampage III Gene - Intel Core i7 990X Extreme Edition - Corsair Dominator GT CMT24GX3M3A2000C9 - 2x Asus ENGTXTOP/2DI/1792MD3
OCZ Vertex III VTX3-25SAT3-60G - 2x G.Skill Phoenix PRO 120Gb - Koolance PSU1300ATX-12N 1700W - Koolance RP452X - 2xD5 pumps - Silverstone TJ08-E - 2x Watercool MO-RA (4x180)
Holy crap!! That looks awesome! More pics please.
^ my old e6600@4ghz with a 7950gt build
im considering ripping out the radiator,pump,res and buying new blocks,tubing and redoing the loop but i need some advice... I bought a corsair 400r will put a pic of it below and currently the h50 isnt cutting it i want 5ghz which this chip can do but due to temps im at 4.7... i dont have much clearance with just one fan if i was to add the black ice 2 radiator and ONE fan it might hit my ram and i wanted push pull the qustion is does it matter if i set two fans on top then the radiator inside the case and two fans under or do thety have to be connected to each other for optimum airflow??
see the space with just one fan so cose =( will it matter if the rad is outside?
Powered it up for the first time tonight! Still needs a few things but the hard stuff is done:
Looking good! As the poster above said, what tower is that?
Could you show some more detail on where you've relocated the PSU to accommodate that 480 rad in the bottom?
