put a fish tank sponge in the reservoir. problem solved.my rack mount water rig from my sig. I haven't opened it for a while and just noticed some dried water wetter, that is no good.
I have 2 120mm med speed panaflos @ 7v blowing over a heater core from a 84 Accord. The reservoir is too small for the full flow of the D5 so it always has air in the line but it still keeps cool. Suggestions are always welcome.
Got mine up and running tonight. Going to add a gpu block and try to stuff another 120x240 rad in the front of the case here in a bit.
Many thanks guys, i really appreciate your kind comments !
I use some china made 50cm led stripe with remote control, it´s available at many ebay shops for around 30-40 US Dollar. You can change the color with the remote control, it´s a nice product !
Hate to break it to you coolmiester. Those dyebombs are going to ruin your system. I learned the hard way that modern cpu blocks are essentially filters, and end up getting caked with the pigment from the dye bombs. Eventually you'll notice that your coolant is near 100% clear again, and that your temps seem to have gone through the roof.
Amazing build overall though. Just get rid of that dye before it's too late...
very very nice sirentire build cost me $725
Nice build!
But how the hell did you get your SSD's to work right in RAID 0?? I've had no success on my EVGA X58 tri SLI. Tried all the port combos and controller configs I can think of. My western digital blacks work fine in RAID 0 however I set them up, but for the life of me these SSD's won't even finish a Windows install. I suspect the newest one might be defective, but I just thought you might know some secret that I've overlooked, other than firmware, clean write zero formats, or whatever.... sorry for the off topic query.
neat pics
I finished this last year but have just joined the forum.
I'm not sure what's going on here. I assume the loop in the lower right that leads behind the white fan is for cooling hard drives and the red spirally thing is the reservoir? Or is it to another res and your hard drives are behind the door in the bezel?
What's the make/model of the spiral reservoir?
