bundymania
- Mar 23, 2007
buy ram waterblock from mips-computer.de
Tempting.....
You're still dumping the same amount of heat into your case regardless of that ram cooler or not. Adding the cooler doesn't magically make your memory make less heat. It makes the memory run cooler because you're pushing air over them. The air absorbs the heat, and is then pulled out of your case through the radiator.
While adding the fan *might* be better for the health of your memory modules, it's arguable that it raises the temperature of your case because of the heat that the fans themselves make.
With an 800D and 3 120's up top, don't you think that you've got more than enough airflow for your modules without that additional fan attachment?
PHK, kind of curious what your voltreg temps are with the 480 setup you have? I plan on doing the same thing and am wondering if I even need active cooling on the cards like you show in your pics. I have two mcw80s on order and bought some zalman ramsinks (low profile blue aluminum ones) just in case I need them.
Also, were you not able to use the 480s fan at all?
New watercooling parts installed as well as an XFX 5870 now at 1ghz. Idle's at 34C and never goes above 49C @ load. Also installed a new radiator and CPU block. Swiftech Apogee XT. I'm noticing better idle temps by a few degrees and load temps appear to be about the same. [H] forum member Jiggaman helped with the setup and did a damn fine job.
Hi, here some pics of my V350
