New Afterburner 2.1 beta 7
Discussion in 'Video Cards' started by Ultima99, Jan 31, 2011.
  1. Ultima99
    Ultima99 [H]ardness Supreme
    4,890
    Jul 31, 2004
  2. TheSmJ
    TheSmJ 2[H]4U
    2,721
    Dec 20, 2006
    Now my 6970's Core Clock OC cap is back at 750 Mhz. Already set UnofficialOverclockingMode in the ini file to 1 and I gained VCore control, but the core clock is still capped.
    I had it up to 950 in beta 5. I thought this was how I raised the cap but I can't remember.
    EDIT: Found this:
    To enable unofficial overclocking in this version it is necessary to:
    - Set UnofficialOverclockingEULA field to the following text: I confirm that I am aware of unofficial overclocking limitations and fully understand that MSI will not provide me any support on it
    - Set UnofficialOverclockingMode to 1 to keep PowerPlay active (may not work on old ASICs), 2 to traditionally disable PowerPlay or to 0 to temporary disable unofficial overclocking path
  3. Ultima99
    4,890
    Jul 31, 2004
    From the release notes:
    Changed way of unlocking unofficial overclocking on AMD graphics cards to make overclocking newbies think harder before enabling this functionality blindly and coming to support forums with fake bugreports
  4. madhatter340
    madhatter340 n00b
    27
    Jan 14, 2011
    I might be totally off base here, but if the whole purpose of the program is to overclock/overvolt, why make it difficult? That's like selling a car and advertising that it will be terrible to work on. Maybe there are a lot of people using afterburner for non-overclocking purposes?
  5. rUmX
    rUmX Gawd
    1,017
    Feb 17, 2009
    I only use AB to monitor the graphs for GPU use/temps/clocks, etc... I use CCC to overclock.
  6. Matrices
    Matrices [H]ardness Supreme
    5,256
    Feb 5, 2003
    The problem is that Unwider is a whiny little bitch who can't handle the fact that his software is worthless for overclocking in Crossfire now, and that people have reported it as such. Harsh, but true. Report any failures in his software and he goes ballistic. Expect BSODs left and right, stuck 3D activity, and mismatched voltages if you attempt CF overclocking on a flashed or shader-unlocked pair of 6950s. When I reported these things matter-of-factly he had a conniption and vowed never to return to the Guru3D forums...maturity at its finest.
    Far better off using RBE and Asus Smart Doctor to raise your core voltage and unlock the OC limit, and then you can use CCC to set OC and Afterburner to monitor.
  7. TheSmJ
    TheSmJ 2[H]4U
    2,721
    Dec 20, 2006
    As matrices said, Unwinder is a shitty asshole. Read some of his posts at Guru3d and you'll see what we mean.
  8. Riddleofsteel
    Riddleofsteel [H]ard|Gawd
    1,984
    Feb 4, 2007
    Agreed, I love Afterburner but I'd never seen a grouchier guy on a tech forum in my life. I'm going to check this version out, I'm on beta 6.
  9. ebilcake
    ebilcake Limp Gawd
    168
    Jan 3, 2008
    Agreed, great software but he has no social skills at all and usually comes of as a complete nob. :D
  10. hajalie24
    hajalie24 [H]ard|Gawd
    1,300
    Dec 22, 2010
    Thanks, I'll check this out.
