New 320W TR4 Cooler from Thermalright
Discussion in 'AMD Processors' started by Geno750, Jul 13, 2018 at 12:56 AM.
  1. Geno750
    Geno750 Gawd
    634
    Apr 28, 2006
  2. MrC4
    MrC4 [H]ard|Gawd
    1,202
    Feb 10, 2010
    Nightfire likes this.
  3. schmide
    schmide n00bie
    29
    Jul 22, 2008
    905g = 2lb
    They should sell a strap/bungee with it.
  4. Nobu
    Nobu [H]ard|Gawd
    1,711
    Jun 7, 2007
    Well, it'd depend on how close to the Earth's center you are. But yeah, 'round about 2lbs.
  5. pentiumiiislota
    pentiumiiislota [H]Lite
    115
    Feb 20, 2018
    I can't wait to see this tested, i love there products.
  6. Nightfire
    Nightfire Gawd
    666
    Sep 7, 2017
    905g = .062 slug. There, you happy?
  7. Nobu
    Nobu [H]ard|Gawd
    1,711
    Jun 7, 2007
    I prefer moles, personally. :p
  8. schmide
    schmide n00bie
    29
    Jul 22, 2008
    A mole is a quantity, not a weight. It is 1g in 1g.
  9. Nobu
    Nobu [H]ard|Gawd
    1,711
    Jun 7, 2007
    Right, so is mass in grams, so it's easily converted as long as you know the ratio.
    Edit: iow, if you know the type of alloy used in the heatsink, you can determine the number of moles by simply plugging in the numbers. Whereas with a pound it will depend on where you are on the Earth, for a mole it only matters how many molecules compose one gram of a substance.
  10. Nightfire
    Nightfire Gawd
    666
    Sep 7, 2017
    So how are you going to measure moles - by counting them?
    With force (lbs and newtons) you can use a scale. For grams and slugs, it is a little tougher. Seperate the materials and then a water displacement?
    Measuring the force is the most important aspect for how the equipment will hold it, so really lbs is a better use than grams... unless you prefer to use newtons.
  11. Nobu
    Nobu [H]ard|Gawd
    1,711
    Jun 7, 2007
    That's how scales work in the first place. You place an object on one side, then you place object(s) of known mass on the other side until they equal out, giving you a known mass (regardless of where you are), gravity pulling down on both sides of the scale cancels itself out (scales measure mass, not as well as weight). If you know the chemical composition of the metal, then you can easily determine the number of moles because you already know the object's mass. There will be some error due to impurities of course, but same could be said about almost any measurement.
    Anyway, I was just trying to be humorous, not trying to start an argument. Obviously, lbs are better for measuring weight than moles...rather, you can't measure weight using moles. lol
    sirmonkey1985 likes this.
  12. Nightfire
    Nightfire Gawd
    666
    Sep 7, 2017
    Yeah its a go-nowhere thr3ad so it is all good. When I said scale, I meant like a bathroom scale that has a spring, which is measuring force directly.
  13. cyberguyz
    cyberguyz Limp Gawd
    257
    Aug 28, 2014
    That is a really nice air cooling solution. Thermalright always made excellent air-based coolers. TR needs more air-based solutions.
    That 160mm fan is just EmoticonSurprised.gif you will need a pretty thick case to enclose it.
    Not sure if it will be useful with the 32-core 2950X though.
