I got a new motherboard a while ago and a new power supply more recently, anyways, the power supply worked great on the first day, including multiple reboots.
The next day (today) I see the motherboard power light is very dim, so I turned the physical switch off and waited (quite a long time) till it faded out.
When I turn it back on, it fades out again quite quickly. But if I leave it off for a long time I can boot in to windows before it fades (and tries to restart a couple of times) it seems as if something might be overheating or discharging.
Before I changed the power supply, I had a couple of strange things happen on the motherboard which may be related. Firstly the rear audio outputs don't work, but the front does, I can live with that, but one time it went in to a power loop when I had a 3dconexxion spacepilot plugged in to a usb3 port.
The power supply is a seasonic platinum 860w and the motherboard is asus Maximus gene v, i7 3770k and titan video card (which I removed while his shenanigans is going on because I don't want to damage it) and some SSDs and an optical drive.
