Networking questions
Amiteriver
Trying to get DSL service in my shop.
Was wondering what the maximum distance from a router (in my house) you can run cable without loosing signal. Also if I was to go wireless how that might effect gaming on a desktop for multi player shooter type games vs direct DSL ?
Thanks
k1pp3r
Cat 5 will run 300 feet without a repeater, wireless is well, it ranges.
gjvrieze
Generally Ethernet can do 328ft +/- a few %..... 1Gb is a little more picky about length then say 100Mb...... So if you are running doing 100Mb, should not have any issues up to 300+ft....
Amiteriver
Hay thanks thats good news, have about 150 ft to go.
Can you tell the difference in Ping / respose time when gaming between a wireless desktop vs the same desktop hooked to a router directly?
Thanks
k1pp3r
Hardwire will always be best as wireless can be prone to interference, performance isn't bad on wireless, I play online games with wireless with no problems.
