Hello all,
I plan on having 4-8 people over for a LAN.
We will play against each other, and also get online to play against others.
What will be the best way to network all of this?
I have two 4 port linksys routers, but I'm sure from reading other posts, a switch or hub would be the best option.
I know if only 4 people show up, I'm going with one of the routers I have.
So which is better for 6+?
HUB or Switch?
We should all be on XP during this LAN if that helps.
Thanks in advance!
HUB or Switch?
Thanks in advance!
