First things first. Here's my knowledge of networking.
- I can plug a network cable into a router
- I know (roughly) what DD-WRT is, and I've used it exactly once
- In college (5+ years ago) I took a general computer course that included some networking. I've forgotten literally everything except: I used some sort of cisco network simulator thing and did CLI stuff with imaginary routers.
OK. So here's what I have and what I want to do with it.
I've a wireless "N" network -- a MiFi 4620L is the access point (thanks, Verizon ) with no provision for wired networking whatsoever. There are generally three computers on the network. (Sometimes four, when I'm playing with Linux and need a connection on that box.)
I also have a slightly old HP OfficeJet 7410, which is the main printer for the house. There's like half a dozen printers in this house -- all but two of which have no ink and/or other problems -- but this one is the primary one. I have no idea why.
It has built-in networking -- but only "B", "G", and wired -- and I want it to be on "N". Can I, using DD-WRT or otherwise, use an ethernet cable and a router, and hook that printer up to my wireless "N" network? I don't necessarily want an off-the-shelf print server, but I want something that basically does that for the minimum cost possible.
Worth noting -- I've got three wireless routers, all Belkin. The newer two (both the same model) may be "N" compatible but are DD-WRT incompatible as of about a year ago IIRC -- that's the last time I checked, I'm afraid. The other is "B"/"G" only and works fine with DD-WRT. I'll go look up the models of the two different types if it's needed.
