Network security architecture help.
Phantum
So I switched the placement of my Untangle server and my pfsense box but now when I do GRC's Shields Up test I get a failed in the category of ping reply (ICMP) but a pass or stealth on everything else. When I had the boxes in reverse order I got a complete pass...what gives?
I have an Actiontec GT704WG which is a modem/router/switch
My Actiontec modem acts as the NAT device so it goes.....
Modem: WAN (DHCP) -----> LAN (192.168.1.1) | Port 1 goes to Untangle
Untangle in transparent bridge mode: LAN (192.168.1.2) ----> LAN2 (bridge) to uplink on switch
Switch: Uplink to Untangle....port 1 to pfsense
pfsense: WAN (DHCP; 192.168.1.3) ------> LAN (192.168.10.1) The LAN connection goes into a netgear switch connecting all internal machines.
Is this the correct placement and setup? Everything connects and works and sees eachother but if I switch the placement of the pfsense & untangle boxes I get a full stealth analysis. so wtf? any suggestions or comments?
Concentric
Hold, so it goes:
--- Modem ------ Untangle ------ Switch ------ pfsense ------ Switch (internal) ---
Well, if the ping reply test fails when you put the pfsense box on the outside that suggests that it's set up to respond to WAN pings whereas the Untangle isn't, no?
xtox
Just seems like Untangle is not blocking pings that's all. There is nothing worry about there and could even be useful for troubleshooting externally.
Phantum
Hold, so it goes:
The configuration is correct but when pfsense is on the outside I get a perfect....when Untangle is on outside it fails only the ICMP reply....
So is this configuration correct in terms of addressing and whatnot?
xtox: Just seems like Untangle is not blocking pings that's all. There is nothing worry about there and could even be useful for troubleshooting externally.
Ok so it's not a huge security hole or anything....?
Concentric
Oh right, just the other way around then? See if there's an option in Untangle to disable pings on the WAN interface?
I believe it just means people can tell that your router is there, so might try portscanning you and such. AFAIK not much to worry about.
YeOldeStonecat
Is there a goal you have in this setup? IMO, double NAT'ing with a transparent bridge in between....I'd do everything I could to streamline that.
PFSense is a screaming performance champ, incredible QoS/Traffic Shaping...excellent for VoIP and online gaming 'n such.
Untangle is slow...really designed for business networks because of all its UTM features.
By having them both..you're losing the speed benefits of PFSense, if it matters to you. Actually having the ISP supplied gateway is the first bottleneck...I'd flip that to bridged mode so that your primary router (UT or PF) obtains the public IP on its WAN interface.
Phantum
So at home you don't really gain much by having a two perimeter network? I'm not paranoid but one could say that I have a narrow minded approach to security meaning that I want the whole 9 yards. I like the idea of a network inside another so as to have two lines of defense. Is it kosher to run just the pfsense box? I want to use snort and possibly both Squid & HAVP.
EDIT: so then my next question is this....being that Untangle is running in transparent bridge mode....and taking into account the fact that bridges only operate on layers 1 & 2.....its really not the best perimeter option? or am I whistling dixie?
Phantum
Thank you sir! After doing a little more fine tuning on my google'ing I found exactly what I was looking for.....however it didn't work! Whodda thought the "disable ping on all interfaces" option still replied with an echo?!?!
cymon
Correct me if I'm wrong, but the perimeter is designed for having servers and so forth on public IP addresses. There's absolutely nothing wrong with having ICMP echo enabled, most of the skiddies anyways are just going to be nmapping large subnets, so even with ICMP blocked, they'll still see you around. If you're not running any server processes accessible to the Internet you have nothing to worry about.
calvinj
Would 2nd this entire statement. I started out with Untangle at home. Slow and hated it. Pfsense is all I'm running now at home.
nmap -sV -P0 ip address / domain. works every time.
Phantum
Thanks to everyone!!! I've been up for 28hrs and working on this particular project for about 18 of those hours....so my current setup is as follows....
Modem--->pfSense---->internal network
pfSense runs Squid....hoping to setup HAVP and/or snort. Is (AV) scanning on HTTP traffic worth it for at home? I mean statistically speaking. Like I've stated previously, all these extra layers of security make me feel better about being connected but if they're unnecessary then...thats that I guess. Thanks fellow H|F'ers (like heffers).
