I had some internet issues last month with my ISP (issues with disconnects..was something at the "pole") and I upgraded to the 200Mbit tier they offer
I did a network upgrade to a Ubiquiti Edgerouter Lite ERLITE-3 Desktop Router (Black) and Ubiquiti Networks Unifi 802.11ac Dual-Radio PRO Access Point after the issue was fixed. I also have a Cisco SG 300-20 switch I'm using for all my hardwire connections that the EdgeRouter is connected to.
Since the upgrade I've been having issues not reaching the speeds I'm supposed to be getting. I rebooted the modem and plugged it directly into my desktop and got the following:
http://beta.speedtest.net/result/6447166107.png
Second try....
http://beta.speedtest.net/result/6447168516.png
On the Edge Router
http://beta.speedtest.net/result/6447180671.png
i can post my configuration from my EdgeRouter and switch if needed.
Second try....
On the Edge Router
