Digital-Vortex
- Dec 11, 2001
Hey all. Im setting up the house network this week, and would like some opinions.
The network will be split, 1 part will be a simple work group, easy for the users, simple, nothing fanceyis needed,so its perfect
The second will be a domain network, Its maily for testing purposes, i wantt o experiment with them while im at college, and get some experiance early.
Im looking at from 5 - 8 computers between users computers, servers, and purpose machines.
The work group wont be a problem, a few machines running XP/2000, and possibly a windows 98 machine. but i dount that.
2 machines on the workgroup will have 2 installs of XP on them, one for the domain, and another for the work group, that way there wont be any conflict between the 2 configs, changes to one wont effect the other.
They will all be running off one Linksys BEFSR41 (I think!) router/switch, (will uplink to another switch if i need to) which will be connected to the internet, and handle DHCP for both networks. The only real issue i have is the with one machine. This machine will be running the internet, and connected to the WAN port of the Linksys. This is currently running windows 95!!!
Sadly the machine is just too old to go anywhere above 95.I know it snot the best choice! but is it a REALLY bad idea security wise?
give me feedback, if you wish i can draw up a diagram if it helps.
Thanks guys and gals
