I've been having a touch time trying to get my wireless laptops connected to my netgear routher. Here is what I'm using:
Netgear MR814v3 (latest firmware Version 5.4_06)
Under wireless settings I have channel 6
WEP -- 128bit encryption and negotiation is on Open System. (I've tried automatic and shared as well)
You can generate a passphrase and then get 4 26 character strings to use as your network key. I've used each of them.
Both the wired and wireless MACs are in the MAC access list and it is currently disabled right now.
Here is the scenario. Router works, wireless works without the encrytion. The DHCP server assigns the appropriate address to my labtop using the wireless connection when all security (WEP, 64, 128 or WPA is disabled)
Once I enable the encryption I set up my laptop with the appropriate channel, and enter in the 26 character string. The SSID is broadcasted, I can see the network. The laptop connects wirelessly, goes throught he "Aquire addrees" and always comes back with the lamo 169.xxx.xxx.xxx IP address. We all know this means there was a problem negociating the IP address.
I've also taken the 26 letter key, copied it to notepad, saved it onto a flash drive from wired computer connected to the router. Then used the EXACT character string that is in the router just to make sure there are no thick fingers.
Frankly, I'm not sure why I can connect to the router but always get the windows assigned 169.xxx.xxx.xxx address. When I run ipconfig, my gateway of course is the router IP LAN address but I cannont communicate.
Now, things I have not tried are setting the encryption settings and then powering off the router, and then turn it back on and connect to it. I am going to try that later but as of right now, I can't connect.
Any Ideas?
Any Ideas?
