Have a used FAS2240 that I need to setup. Don't have the current password, so I am trying to just do a factory reset. I keep finding steps that say to press CTRL+C during the boot up to select an option for initializing all the disks. However, I can never seem to get to that menu. Below is a screen shot.
It never says press CRTL+C for special boot menu. If I press CTRL+C at Abort, it brings me to a prompt, but I don't know what command would wipe it. I typed in "priv set advanced" and it warns you about using those privileges, but that it about it. If I do CTRL+C where it says Boot Menu, it just seems to keep going and doesn't give any options. So what can I do to get this thing going?
