Need your opionion on this MSI hd 6950 quality
JJ91284
As far as that card goes, it will probably unlock but its probably going to run warm.
I just unlocked 3 of these today 6950's to 6970's
http://www.newegg.com/Product/Product.aspx?Item=N82E16814127562&cm_re=6950-_-14-127-562-_-Product
Tried unlocking 2 of these and didn't work, AMD Laser cut the these newer ones so you can't unlock the remaining streaming processors.
http://www.newegg.com/Product/Product.aspx?Item=N82E16814127575&cm_re=6950-_-14-127-575-_-Product
Safest way to unlock the streaming processors. The two cards that had their streaming processors cut still boot fine and work with no issues.
http://www.tomshardware.com/forum/316974-33-radeon-6950-shader-unlock-instructions#t2368661
I have a reference xfx hd 6950. I was looking for another reference card for CF. So you only recommend unlocking just the shaders and leaving voltages alone. Do you overclock your unlocked cards?
DeChache
I have the MSI card and know of 3 others out there and none of us have had any issues
shawnmramsey
So far what I have to say that both of my MSI 6950's have unlocked and overclocked to 950, I try to not push the ram as much as I want 'cause know the mem has a little lower standards compared to the 6970.. Temp stay nice too.
Try if you can to get a reference card.
So just be carefull with the memory
{uZa}DOA
IMHO MSI is a solid brand... I haven't unlocked a 6950 but, like all OC/unlocking YMMV...
note235
the reference one is still unlockable
im planning on buying 2 more, but are all twin FROZR unlocable?
