Need XP Home ISO
Ravenrex
I'm not looking for warez or anything illegal. Mods delete this if it goes beyond the bounds of what is legal here in the forums.
I need an ISO image of an XP Home CD so I can reinstall it for someone. I have the CDKEY on the sticker on the side of the PC, but my friend lost the CD and the only ones I have are PRO disks. This shouldn't be illegal since I will be activating it with his original key so nothing funny going on. I just need a link to somewhere that I can get the original CD, no cracks or keygens please.
it is possible, if he has a prebuilt system, that there never was a cd... but instead there is a norton ghost partition on the drive... so you would just need to find a "repair/recovery" disk that came with the computer.... amamax had this http://amamax.com/wi20proprein.html for xp, but i think it was pro.. you can search their site..
but i think finding home on the warez scene will he really hard.. because people only use corporate pro...
S1nF1xx
It's not really illegal to burn a disk of XP. You have your CD key and that's what matters. The problem is, did you have a full copy of XP to begin with? Or did you get fux0red and get a restore disk? Either way, you want a real copy of the original disk. So either A. Contact Microsoft and tell them what happened, I'm sure you can get another disk. Or B. Contact Dell or whoever built the machine and get a new restore disk.
You will not find a legit copy of XP for download on the internet.
Hope that helps you before the lock.
Ravenrex
It is a legit OEM copy, not a branded one from Dell or Gateway, the boob just lost it, but the sticker with the CDKEY is still on the machine, so if I can get the ISO of a Home CD i can use it to reinstall. I DON'T NEED OR WANT A KEY OR KEYGEN.
BillLeeLee
If the OP has a legit license for XP Home, he can install off whatever XP Home cd he gets, even if he downloads an .ISO.
However, since posting a site is probably not allowed in this case, Ravenrex, because such places could have other software (or links) that are pirated, I'd suggest getting information on a Bittorrent torrents website. Shouldn't be that hard. You could also feasibly download an .ISO off kazaa, though I would not recommend that since kazaa is a den of computer diseases.
Too bad you don't have a Pro OEM key, I'd send you one of my many OEM Pro discs.
hulksterjoe
older and wiser now
You'll also need to make sure you get the correct iso...
There are a few
OEM
RETAIL
Corporate
But if what your saying is correct that its a straight oem. Then you really shouldnt have any problem getting a disk.. Heck you could probably find someone near you to bring theirs over.. or do you have any local computer stores ( not national ones) they might even take pity on you and let you use theirs for 1 hr
nomar
I think your best bet is trying to find someone local to you that has one. Unfortunately it will be tough because a lot of OEM versions will only install for that brand of computer.
Ravenrex
Heh, found this as a torrent:
Welcome to the Windows XP Professional, Home Edition Super CD (English Version)
This is a multi-bootable Windows XP Super CD which put 5 different English versions of Windows XP Professional and Home Edition together into one single CD. Other than multi-bootable, the CD is equipped with an Autorun CD-Menu to make it more user-friendly under win32 environment. There is a Tools Folder which contains useful tools, and utilities to be used with the Windows XP.
Features:
Windows XP Professional, Home Edition 5in1:
Primary Windows XP Professional Edition, MSDN Volume License Version, i386 folder located under \
Alternate Windows XP Professional Edition, Retail Version, i386 folder located under \WXPFPP
Alternate Windows XP Home Edition Edition, Retail Version, i386 folder located under \WXHFPP
Alternate Windows XP Professional Edition, OEM-DELL Version, i386 folder located under \WXPOEM
Alternate Windows XP Home Edition, OEM Version, i386 folder located under \WXHOEM
CD is bootable into a main menu from which you can select to install anyone of the 5 XP's.
CD is also bootable into Windows 98 DOS [Version 4.10.2222] from which you can run extended DOS Commands or run NTFS_PRO to access NTFS Partitions. There is an additional option in the main menu which offers you to run Partition Magic 7 from a RAM drive upon booting the CD. This enables you to work on partitions of FAT, FAT32 and NTFS under DOS environment.
Under Win32 environment, the Autorun CD-Menu will allow selection of setup anyone of the 5 XP's when this CD is inserted. The Autorun CD-Menu also offers to run the XP-Key Generator which can generate Product-Keys for Windows XP Professional/Corporate/Home Edition as well as Office XP Pro/Plus and Visio XP Pro.
Corporate files (under \CORPFILE), Final-Patches (under \FNLPATCH), WPA-Patch Programs & XP-Key Generator (under \WPAPATCH), XP-Identity Files (under \XPIDFILE) and Patched Winlogon's (under \WINLOGON) are included.
Tools and utilities included in the Tools Folder are: ASPI32 Layer, DivX Codec, MP3 Codec, PowerToyXP, CDRWIN, WINIMAGE, DaemonTools, ISOBuster, CD Mate, WinISO, FlashFXP, HardCopy, IrfanView, Resource Hacker, UltraEdit, WinRAR and WinZIP.
Ravenrex
That's a dead torrent, already found and tried that. Better just delete that link compslcker.
The[H]uman
Secret Agent Man
Write me a e-mail I will get a copy out to you in the mail for the cost of the cd and the shipping not a big deal don't spend all the time looking around not sure why somebody didn't suggest this to you before hand but all good.
bradley.n@gmail.com
xphantg0d
Aren't 5 in 1s conisdered warez and illegal? I know a place that used to have them and took them down cause they said they are considered warez.
TheCzar
that supercd sounds pretty spiff...I guess its too bad I actually own a copy of XP...otherwise I might give that a shot...
