Personally, I would probably switch it over to 2000 (if you can find a license for it nowadays?) on both the server and workstation fronts. Obviously the office doesn't require the latest and greatest if it's been working off of NT 4.0 for this long.
However, depending on the budget/needs here, it could very well be easier / a better option to do a major upgrade on all the hardware and move to SBS2008 and Windows Vista Business computers. This of course depends on what software their using, and whether they can afford to change that out, which they could very well have to either way.
Lastly, unless the NT setup is causing any issues, why change it?
I switched my Lawyer from NT to XP/2K3, he was very very happy.
Yeah, XP/2k3 is pretty much the solution most companies are using at the moment (those who aren't still running Win2k Pro/Server ). In many ways it's pretty much no-brainer to switch to this combination.
^ i would not be throwing vista in any mix.
we decided (our office) we will keep recommending all our clients to stick with XP, all new machines will be XP Pro and then Windows 7.
skip vista, so slow in a business domain network.
But yeah Server 08 would be in my mix.
Agreed, Server 08 is a great server OS but Vista really isnt something you want to stick in a domain. Vista still has it quirky errors here and there and thats something the IT staff isnt going want to troubleshoot.
I'm doing a favor for someone. His office currently uses NT 4.0...God knows why.
Any suggestions about which OS to switch to (2000, XP Pro, etc.)?
Stability is my main concern and I don't know much about networking.
Finding a 9.1 GB SCSI 2 drive ain't easy. I shudder to think what will happen when a MB goes...
If it wasn't for a pile of spare parts kept from other servers of the same type when they were decommed. Shudder.
However, he wants to upgrade the server to a more modern OS (I proposed SBS 2008). I think if that happens then we might as well upgrade the two clients.
Too bad Windows 7 is just around the corner.
I haven't heard anything yet from my Dell rep about Software Assurance from XP/Win7. So I emailed waiting for advice.
Nothing wrong with sticking with XP Pro, its gonna be a huge upgrade for them. And just so you know Dell has been doing those $550 Optiplex 360 deals - 2.8s, 2gb, 250gb drive, dvd burner, XP pro, 22" LCD
I have 5 on order to stock, take those over Vostro
