Since I'm getting a 360 now I'm going to get a router for them to both share my cable connection.
I was thinking of Wireless Vs Wired.
At first I was going to go wireless, but since I play to use my xbox on my computer monitor/sound system it's going to be close to my computer already, so I don't really need to do I?
I was thinking about going wireless with this modem: (the <rev 3 or under one)
http://www.newegg.com/Product/Product.asp?Item=N82E16833124010
However after a while when I started to think that wired probally would be fine I found this modem:
http://www.newegg.com/Product/Product.asp?Item=N82E16833127013
Which one should I get?
Also there is quite a bit of a price difference too. With the wireless modem I would have to buy an adapter to hook it up. However with the wired one I already have on-board ethernet so all I have to do is buy another ethernet cable and i'm good to go.
However speed-wise/stability, etc what am I going to get? I usually think with the mindset of "you get what you pay for" however the d-link modem has quite a few very good reviews for it, aswell it's xbox live compatible and everything.
