I have a amd 2950x and a asrock x399 taichi and i need a 64gb ram kit ,quad channel, composed of 4x16gb stick that will run at least at 3200mhz xmp stable.I checked the asrock qvl list but there isnt enough info/tested stuff there.Which gskill kit coud achive that speed stable with that amount?
I did saw this kit :
https://www.gskill.com/en/product/f4-3200c14q-64gtz
But it says that is dual/quad channel kit and i dont understand this.It means that is dual channel if i use only 2 of the 4 sticks and is quad channlel if i use all 4 sticks?
There is also this thing
https://gskill.com/en/product/f4-3466c16q-64gtz
but is cl16 and that is not a samsung b-die, and i understand that that is what threadripper likes.
Any way, what coud you guys recommend me?
Thank you.
Thank you.
