Need to buy a SSD today...
Discussion in 'SSDs & Data Storage' started by Trepidati0n, Mar 13, 2016.
  1. Trepidati0n
    Trepidati0n [H]ardForum Junkie
    8,826
    Oct 26, 2004
    SMART starting to throw errors on my primary HDD. Finally going to jump to SSD. Would like storage between 250-500GB. Don't need stupid good performance. Haven't seen any good aggregate SSD drive reviews lately and not sure what is worth getting and what is worth avoiding.
  2. SomeGuy133
    SomeGuy133 2[H]4U
    3,447
    Apr 12, 2015
    Get any of these:
    Performance ~= depends on needs, which is better
    Extreme Pro (Sandisk)
    850 PRO (Sammy)
    Budget but still good get whatever is cheaper
    MX200 (Crucial)
    850 EVO (Sammy)
    Basically sums up whatever is worth buying. There maybe a hidden gem or something but these are your safe bets
    Extreme side and a waste if you don't actually need it:
    950 PRO
    Intel 750
    (note this is assuming 500GB or more. 256GB performance difference substantially more because of the less amount of chips.
    MX200 500GB for $135
    500GB Crucial MX200 2.5" SATA III Solid State Drive $135 + Free Shipping
    thats your best bang for your buck
    drescherjm likes this.
  3. ToddW2
    ToddW2 2[H]4U
    4,019
    Nov 8, 2004
    256gb or 500gb 850 Pro is what I'd get since it sounds like you don't upgrade often :) warranty is likely worth it.
  4. SomeGuy133
    SomeGuy133 2[H]4U
    3,447
    Apr 12, 2015
    not with SSDs....that 500GB drive will be work 50 or less dollars by time it crashes...not worth the time.
    Anywauys if warranty was the issue the Extreme Pro has better warranty.
    but again my 480GB is still working with 55TB of writes and i bought it at 270 and its like 170 bucks now. SSDs are basically disposable with how fast NAND is evolving.
  5. diizzy
    diizzy 2[H]4U
    2,602
    Nov 6, 2008
    Crucial MX200, Micron M600, Samsung 850 Pro, Plextor M6S Plus, M6 Pro, M6S
    I'd avoid Phison, SMI etc controllers...
  6. SomeGuy133
    SomeGuy133 2[H]4U
    3,447
    Apr 12, 2015
    a lot mention the m600. I heard its good but never seena review...too busy at the monemt to check up on it but i would be surprised if its really competitive overall but if it is i should take note :D
  7. Trepidati0n
    8,826
    Oct 26, 2004
    Went with the 500GB EVO. Just can't justify the $ for the extra performance i'll never use.
  8. WangChung
    WangChung Limp Gawd
    181
    Dec 19, 2013
    I saw that you already bought a drive, but just came to advocate for the Mushkin ECO drives @ Newegg. Especially for a drive that's mostly going to be read from (games/media) the price point of their drives is great. I've bought three so far and have nothing but positive experience with them.
  9. Trepidati0n
    8,826
    Oct 26, 2004
    Thanks for sharing. It can't hurt since others searching will see a thread like this and may value the information.
