I've gotten to the point where my media is stored across too many systems as well has having a ton of personal data with redudancy being provided by external USB HDD's. It's gotten untenable and I need to beef things up a bit. I was hoping to run ESXi for 2-3 VM's now and potentially more later on.
VM1 - PFSENSE with 2 dedicated NIC's.
VM2 - Windows Sever - DC / Shared Storage / Print Server
VM3 - Windows 7/8 Guest
Overall goals:
I am trying to be budget conscious about this, as I know the commercial grade hardware I'd like to use will get expensive quickly. While I would like to all out buying every component individually, the cost is prohibitive, and I likely would not get the value back out of a $3k+ investment. So, you can see the option's I'm weighing below. I may be greatly overestimating how powerful of a server I need.
Current bare metal systems to consider.
C2D Asus P5K-E (P35) - PFSENSE firewall. (65w power usage 24/7)
Core i3 Asrock Z77-Pro4 - HTPC / media storage center (I'll find power usage when I get home)
___________________________________________________________
Proposal 1:
Repurpose C2D sytem to be HTPC (would work fine)
Repurpose Core i3 system by upgrading to Xeon socket 1150 processor with VT-d support and adding more RAM (Currently 8GB).
Pro's
- Cheapest and fastest option
Con's
- 32GB max memory on z77 motherboard.
- Substantial limitations to expansion of storage.
Proposal 2:
Buy a used 12-core (Dual six-core) xeon workstation with VT-d support.
Decommission C2D PFSENSE BOX.
Notes: I've been eye-ing the HP Z800. There's a lots of dell T7500's out there that can be had for cheap. But the internals of dell's machines look like a nightmare.
Pro's
- Relatively good bang for buck (~$1k or less)
- Big OEM gear of this grade is usually highly reliable
- Better room for expansion, but still somewhat limited
- Can be found with quality RAID card's preinstalled
- Very powerful system
Con's
- Might break my goal for power consumption (Trying to stay under 200 watts)
- These machines usually have proprietary hardware (PSU's esp) that will be hard to replace should something break 5 years down the road.
- Have to deal with shady vendors on ebay.
Proposal 3:
Suck it up and and build my own socket G34 opteron server (Supposedly great for VM, and a lot cheaper than xeon when buying new)
Pro's
- It's all new
- I get to use standard hardware for easy replacement
- I get to design for maximum expansion capacity
Con's
- Still super expensive
Overall goals:
- Run all needed VM's while idling at under 175 watts.
- Will be within earshot of living space, so quiet operation is important.
Proposal 1:
Pro's
Con's
Proposal 2:
Pro's
Con's
Proposal 3:
Pro's
- It's all new
Con's
