KnishofDeath
- Aug 27, 2004
I am building a new custom water cooled system with an i7 6700k. Long story short, I need a cheap, but adequate heatsink and fan combo to run a test boot and get the OS and drivers installed. In the past, I would have used the stock fan but as it doesn't come with one, I need to look elsewhere. Looking to spend max $30 as this will only be temporary and will be swapped out for a full water cooling loop with EK blocks. Any suggestions? I won't be overlocking obviously. So anything that will run cool enough to be stable for a test boot to make sure everything is working and then install the OS, drivers and software will be more than sufficient.
Mobo is Gigagbyte Z170 Designare.
Thanks!
Thanks!
