A guy i know wants to grab a wifi signal from a little over a mile away. The place he wants to put the antenna is ontop of a hill and the signal is in a vallyish thing below. I'm a bit confused about something, however. If he puts a high gain antenna on his end, does the origin need an equally powerful antenna or will the standard wireless hub antenna be able to pick up his signal and provide enough power for his antenna to pick it up. This is going to be used with a laptop, so i need to find a card that has an external antenna connector and an antenna. If you've had any experience with this or can provide suggestions for the card/antenna, please do. I'm just not sure if it'll work with only 1 end having a good antenna. Just don't know enough about wifi. Thanks.
