I will post some logs later, when I can dig them up.......
Here is the issue.
I was getting a lot of logs for terrible disk latency accessing datastores, like in the 20k ms range
Eventually I dropped my VM datastore completely back in Oct
(yeah I use the VM's a lot...clearly.....but my media server is on it and I started needing it again
Yesterday I swapped out the perc 5i for another perc5i and everything came back seemingly happy
minus the VM freezing randomly for a few seconds.
I figure I need to make them do some work and then check the logs again and see if I get some errors......
running 5.1(yeah I need to patch up...bad...)
its a amd 880 chipset, with a thuban x6 at 2.2ghz and 8gb of ram
the vm is server 2008r2
disk setup is...
esxi on a flash drive
vm datastore is 2x500gb sata in raid 1
my storage datastore is 4x1.5tb greens in raid 10, which are mounted to the server 2008r2 vm
I have a Linux vm and a server 2012 vm but I shut them off to aid in troubleshooting
I have literally never had to troubleshoot anything in esxi before.....ie I'm sure I've had issues but never bad enough I noticed....
posts to RTFM will be noted and are deserving...
Here is the issue.
disk setup is...
