need some help
lukeh182
this is what i want to do:
set up a file/print server
this is what i have:
cable modem into
4 port router into
2 computers
can i setup another computer to be my print file srever with my current equipment? (i have another comp to use for the server) or do i need other stuff? like a switch etc.
if i can do it with this stuff, how will it be wired? will i use 2 NIC in the server?
ktwebb
As far as the physical part of it: Put a NIC in your server, plug into an open port on your routers switch with a cat5 patch cable. Set up your shares and printer share.
