Blitzrommel
- Sep 26, 2001
I saw a post a few months ago on how to reset it to factory settings, but I couldn't find it -- how can I do that without using the comm port?
Sure, I have physical access to it. If that's what you meant.Originally posted by kleptophobiac
Can you open up the unit to do the trick?
Tried that -- no good.Originally posted by djdk
Might be a long shot, but try "secure"
Apparently there is a problem with Baystack 350-24t switches and Windows XP HyperTerminal, and while setting the password, it went to its default when a password is enabled. It took me forever to figure it out, but it ended up setting itself to secure.
Originally posted by Joony
for some reason I can't console into my Baystack 350-12T, do I have to use some sort of specific cable serial cable?
