I'm about to setup a wired network throughout the house. I was going to go ahead and buy one of those network kits w/ everything you need, however, according to my parents, the house was wired with Cat V a few years ago (like around '98 or '99) when it was totally redone on the inside.
The problem, though, is that this doesn't look like any normal networking cable. Looking at normal Cat-5e cable, I see many different colored wires within the rubber enclosure. Looking at the Cat-5 cable in the walls, it's got what looks like a copper wire maybe twice the thickness of the little ones in the 'normal' cable, surrounded by what I guess is white insulation that probably has a diameter 4 times that of the wire (I know nothing about wiring), which is then surrounded by very tiny strands of metal wire all the way around it. If it helps any, here's what's written on the Cat V cable:
E83032A F660BVV (UL) Cat V
Does this mean anything?
So I guess what I'm asking is, can I crimp network cable connectors onto this? I've never created my own network cables, but from what I hear it's rather easy, using the standard cables and connectors of course. I don't have any pictures to take because the camera I have really sucks, and it's just a black and white blur of the cable up close. Sorry if I'm really vague on this, but I'm just working with what I have.
