Need some advice and help about overclocking (8700k)
Discussion in 'Water Cooling' started by Elric82, Nov 11, 2018.
  1. Elric82
    Elric82 n00b
    27
    Jul 15, 2017
    Hi !
    I have a delid cpu, maximus hero X, Eisbaer LT 360 for cooling
    First question is about the manual OC
    i've tried to set up an oc profile but I have some questions about it
    Tried at 48 all core
    XMP profile
    manual override
    vcore 1.26
    LLC 5
    Cache 42/42
    C state on
    BCLK Aware Adaptative Voltage : Disable
    Internal CPU Power Management : Long Duration Package Power Limit : 4095 Max)
    Internal CPU Power Management : Short Duration Package Power Limit : 4095 Max
    IA DC Loadline : 0.01
    IA AC Loadline : 0.01
    Spread Spectrum : disabled
    My temps are around max at 68 degres on some cores in cpu demanding games
    At idle it's around 37 but i got spikes to45 even 50 at some point when i launch chrome for example. It does not last at all but I was wondering if its normal.
    So i was wondering if those temps are ok and if i should tweak other settings.
    Some people tell me it's fine, other that they have lower temps without delid of with higher OC so iIdon't know what I should think. Someone on a FB group just told me that at 5GHz, with a vccore at 1.35, gaming never goes over 50° for example, i find it very very low even with a perfect delid no?
    I was told that maybe the delid was botched.. Haven't done it myself so I don't know and I don't feel comfortable enought to do it
    Second question : I tried to set up an adaptive profile at the same clocks.
    SVID Enabled
    SVID behavior : best case scenario
    addtional turbo mode core : 1.265
    offset -
    BCLK Aware Adaptative Voltage : Disabled
    Min cpu cache ratio : auto
    max cpu cache ratio : 44
    Without putting auto on min cache cpu ration, the vcore wasnt dropping when idle.
    The issue here is that I realized in adaptive setting, there was a weird sound coming out of the cpu, something close to the sound of a working HDD mixed with a buzzing.. No Idea what causes that, if someone has some idea?
    Thanks for the help
  2. SticKx911
    SticKx911 2[H]4U
    2,093
    Mar 14, 2004
    Never heard of cpu noise, but 68° is nothing to be alarmed at. The jumps to 50 are just points where the loop didn’t have ability react immediately and also normal.
  3. Elric82
    Elric82 n00b
    27
    Jul 15, 2017
    Well it's more a noise coming close to the CPU, only in adaptive mode. Sound like electric buzzing mixed with a sound of a working hard drive . Weird.
    On another forum, some people told me my temps were too warm for a delid CPU claiming their8700k was around 25 idle and 50 max gaming or during cinebench.
    Even for a badass CPU with the most awesome delid, i have trouble to believe that, am I right?
  4. SticKx911
    SticKx911 2[H]4U
    2,093
    Mar 14, 2004
    If you’re running your fans full on with a 360, I would think it’s higher than average.
    If your fans are running low or near off (pwm control), that’s not a crazy number. How are your fans powered/controlled?
  5. cyberguyz
    cyberguyz Gawd
    694
    Aug 28, 2014
    Contrary to popular belief solid state components are not necessarily quiet - especially when they are switching circuits. PWM controls switch power on and off at various frequencies to control the amount of power going through circuits. This switching can be heard as a low-volume (or sometimes louder) high pitched buzzing. The faster the switching and shorter the pulse width, the higher the buzzing pitch. A computer motherboard is full of PWM switching circuits that do make this high pitched buzzing noise.
  6. Elric82
    Elric82 n00b
    27
    Jul 15, 2017
    My fans are on a rheobus so on idle i just leave them around 50%. When i'm gamind or doing something more heavy, I push them 100% so i guess there is a little issue somewhere maybe?
    Ah ok well it was annoying I must say so I guess i'll keep my manual OC profile
    Vcore goes from 1.248 to 1.264 on this profile, probably because of LLC?
    What should be my temps during gaming on demanding games ?
    Are there other settings i should tweak for better temps?
  7. Elric82
    Elric82 n00b
    27
    Jul 15, 2017
    Little Up.
    What should be my settings for
    CPU VCCIO Voltage
    Cpu System agent voltage
    I have 3466mhz ram
    Also, what about CPU standby voltage?
    Should I put CPu phase control to extreme?
    Thanks
