Flogger23m
- Jun 19, 2009
Been using a Logitech G Pro for almost three years but the rear side button now double clicks. I use this as a back button and I can no longer tolerate the double clicking as it happens every 1 out of 5 clicks.
I purchased the newer G Pro Hero, which is almost identical to the older model but this requires new garbage bloatware called "Logitech G Hub". It features all kinds of bullshit like product advertisements, profiles for games I don't play, an impossible to figure out GUI. But they forgot to add functionality to save a profile to the onboard memory so you can disable the bloated software from running 24/7. The old software worked flawlessly and you could change your settings, save it to your mouse and never open it again. But that is gone. I will not run software for a mouse 24/7 so I will return this turd.
Need something similar in size/shape, onboard memory that doesn't constantly require software running 24/7 and some durable build quality. Not interested in buying a new mouse every 2-3 years. Would prefer wired.
