I need a cost effective printing solution. I have an old router that I am using as a print server. The only problem is that newer printers don't have the parallel interface (they are USB). I would like to get a printer that I can refill like the Canon IP3000, IP4000, etc. These seem to be my four options:
1. Get a new USB print server and printer
2. Find a printer that has a parallel jack. (Only one I have found is the IP4000 which is pretty expensive).
3. Get a network capable printer and eliminate the print server.
4. Get some kind of parallel to usb adapter that I can use on my current print server (Is there even such a device?)
Which solution costs the least (also in terms of refill ink costs)?
What equipment do you recommend I buy?
TIA
TIA
