I need some help/advice. I bought a Netgear Nighthawk R7000 and was not really blown away like I thought I would be with the range. One thing I noticed using my Galaxy S3 was that my link speeds were low. It didn't really seem to show in performance but I would see link speeds of 6 or 11, etc. Even when in the same room as the router it would show low speeds. So I ordered a TP Link Archer C7 which is what I was going to get to begin with. The link speeds on this seem erratic also, but are higher than the Nighthawk. However the range and signal strength is not as good as the Netgear. I am coming from a Linksys WRT54g, and I am used to seeing constant 54Mbps link any time I would check it. But the range on it was very poor. So I'm confused on what to keep and what to return and what I should really be looking at. All the different reported speeds vs. performance is not adding up to me.
