Need laptop for secondary PC, learning Linux
Discussion in 'Mobile Computing' started by FlamingTP01, Oct 13, 2018.
  1. FlamingTP01
    FlamingTP01 [H]Lite
    82
    Sep 27, 2018
    On my journey to build a new computer, I picked up a dell XPS 13 at costco to use in the meantime. the screen has a vertical line of dead pixels, no visible damage, going to return.
    Anyway, I need a laptop for general work, web browsing, learning Linux, and as a backup so I can access the internet and diagnose issues with my regular PC hardware.
    My only needs are this: Standard USB A, and a fast processor for boot up and "instantaneous" basic tasks. I also want to use it to help me learn Linux.
    Most likely use case is table top, plugged in.
    budget is $500-1000 not including shipping and taxes. Honestly I'm surprised it's not that easy to find a 3-400 dollar laptop with a 3+ghz modern CPU and garbage everything else just for this sort of task.
  2. dthree
    dthree n00b
    28
    Apr 5, 2016
    Are you asking for recommendations? Plenty of deals out there.
    Check slickdeals, wait for black friday, or try ebay/forums/craigslist for used laptops
  3. FlamingTP01
    FlamingTP01 [H]Lite
    82
    Sep 27, 2018
    Forgot about black Friday. Mostly just looking for recommendations. Most things you can typically pick up at a store are either way too slow for even basic office work or they are just overkill. I wish you could build a laptop just like you can a desktop.
  4. defaultluser
    defaultluser I B Smart
    12,147
    Jan 14, 2006
    You don't need a 3+ ghz processor for instant-response on a notebook, you need a 2.5 ghz processor with an SSD.
  5. FlamingTP01
    FlamingTP01 [H]Lite
    82
    Sep 27, 2018
    Alrighty then, if that's all I need there should be something locally available then. Thanks for the input.
  6. defaultluser
    12,147
    Jan 14, 2006
    Just make sure it's a Core i3 2.5GHz or better and you'll be fine. No Pentiums or Celerons (because half the time those are rebranded Atom cores)
  7. FlamingTP01
    FlamingTP01 [H]Lite
    82
    Sep 27, 2018
    Oh I know about the celerons trust me. I'll probably pick something up this weekend.
  8. pendragon1
    pendragon1 [H]ardForum Junkie
    11,610
    Oct 7, 2000
    dell has some good deals and the latitudes are built good. you can get an elcheapo if you want but what was said about the cpu and ssd are very good points.
  9. toast0
    toast0 Gawd
    901
    Jan 26, 2010
    Pentiums and celerons are fine enough, as long as you check that it's not an atom; it's a pain to check, especially since Intel has started naming atom's somethinglake and making it even more confusing, but if you get the core count and speed that you need, then it's just binned slower chips with stuff like hyperthreading turned off.
  10. 123Lanoix
    123Lanoix 2[H]4U
    3,750
    Nov 13, 2005
    System 76 sells laptops with ubuntu on them
