kill4killin
- Jul 3, 2006
Ok, so, the rig that is in my sig is currently at 3.2Ghz stable at 1.4Vcore...I want it to run faster but I have a catch. I am only running it on DDR2-667 right now because I haven't had the money to order the actual RAM that is in the sig (though it will be there soon). Until then, I would like to see if I can push my computer any further using the 667. I have it running at 370 x 9 and once I get up around 375 it starts to get unstable because of the FSB hole that the motherboard has (between 374 and 399). Well, once I make the jump over the hole it is unstable because the RAM is then running 67Mhz over stock speed and it is starting to get a bit fussy. I am running the RAM to 2.4V and the highest it can go is 2.45V (and I can, it stays cool to the touch ). So any suggestions as to how to get it to stay stable at 400Mhz?
The RAM is at a 1:1 ratio because it can't go any lower, running at 2.4V and using a 5-6-6-18 timing, the loosest it will go and not crash) just so you have the info on the RAM.
