paulmofyourhand
- Mar 26, 2002
the system will consist of :
intel Pentium D 2.66ghz @ ????
2gb ddr2
160gb sata
6800 non ultra@ 16pipelines (will be in loop)
ill be using the blue vga and cpu waterblocks from Zalman with a switftech pump.
i want to run with a minimum amount of fans. possibly only the one that is built into the power supply unit.
i found a passive radiator from (i think) Innovatek that mounted on the side panel and cost $150 (more than i'd like to spend) i was thinking $40-$50
and would like to build a resovoir like the one at frozen cpu that act as a passive cooler at the same time.
the main object of the build would be a low budget passive system, and would fit on a standard size mid-tower ATX case.
im a diy person, so any input would be good.
2gb ddr2
160gb sata
