I've been testing my system and I've found that VC-1 WMV files are not playing well on my system.
1080p VC-1 .wmv
720p VC-1 .wmv
1080p AVC .mkv
720p AVC .mkv
So I've been troubleshooting this. I've been playing with the MPC-HC settings, filters, been tweaking FFDShow DXVA Decoder settings. I just can't seem to get the VC-1 files to play smoothly.
Opening up mediainfo, it tells me my system doesn't support VC-1 playback. How can that not be? I thought Win7 or WMP12 would have it enabled by default.
I know for a fact that the .mkv files were playing fine in Windows Media Player, but I must have screwed something up these past few hours "tweaking" things. I'll do a system restore and it back to a working condition.
On to the nuts and bolts:
Athlon s393 X2 4400+
4gb DDR Ram
AMD 4890
Win 7 x64 Ultimate
MPC-HC (Latest from xvidvideo.ru)
FFDShow Tryouts (latest x86 and x64 builds from xvidvideo.ru)
Latest Haali Matroska Splitter.
Any tips on getting these VC-1 files to work?
EDIT: I should note, I normally use MPC-HC as my main player, so I'm mostly interested in getting them to work with that player. I only have VLC Portable around to test things when it doesn't work in MPC-HC. I will use WMP if I have to, but I'd prefer MPC-HC. Thanks.
1080p VC-1 .wmv
- Refuses to play in WMP (Get error message)
- Begins playing in MPC-HC (latest) but quickly lags/stutters out.
- Plays fine in VLC Portable (latest) but has stuttering/blockiness when skipping forward or backward.
720p VC-1 .wmv
- Plays audio but no video in WMP.
- Plays in MPC-HC (latest) but lots of blockiness/discoloration.
1080p AVC .mkv
- Doesn't play in WMP. (I think I've screwed something up messing around trying to get the VC-1 files to play)
- Plays fine in MPC-HC (latest build) but with slight stuttering when skipping forward/back.
720p AVC .mkv
- Plays fine in MPC-HC (latest build).
- Plays fine in VLC Portable (latest).
4gb DDR Ram
AMD 4890
Win 7 x64 Ultimate
