Im trying to use remote desktop to control my htpc with my tablet. Both have win 8.1 pro installed and the htpc has been set to accept remote connections. Whenever i try to connect though, i get an error:
Remote Desktop can't connect to the remote computer for one of these reasons:
1) Remote access to the server is not enabled
2) The remote computer is turned off
3) The remote computer is not available on the network
Make sure the remote computer is turned on and connected to the network, and that remote access is enabled.
My google-fu hasnt yielded very much success on resolving the problem, so here i am, asking for help.
edit:
I poked aruond some more and got it to connect by disabling the firewall. Now that i have the connection, i have another problem.
I was hoping to mirror the display, but instead the htpc display logs off. When i log back in, the connection ends. Am i missing a setting somewhere, or am i expecting the wrong results from remote desktop?
edit:
