MGCJerry
- Sep 18, 2005
Go ahead and laugh, but I recently (3 days ago as of this post) built a AMD FX-8120 machine to replace the loud, hot & obnoxious DL360 rackmount server ive been using for the past year as my primary machine.
Anyway, I had acquired a Sapphire HD4870x2 from a friend online several months ago and it appears that only one processor is operational.
* I only have one 4870 listed in device manager
* GPUz only sees one
* Catalyst sees just one
* Catalyst AI has been set to both advanced & normal with no change
I've tried installing the drivers off the CD, as well as doing a fresh install and using the newest drivers from Sapphire all to no avail. However, the machine does seem to run better with my last reload. So, my question(s) are...
Of course the x2 has 2 processors on one board, so perhaps they're mirrored like RAID 1, so what I'm seeing is normal? Can anyone else whose owned this card confirm or deny this. I've seen plenty of idiots online in my google search whose answers are all over the place. Thanks in advance for any information.
Relevant information:
* Asus Sabertooth 990FX mainboard
* AMD FX 8120 CPU
* Windows XP (Win 7 will be dual booted later)
* Sapphire HD 4870 X2...
* AMD FX 8120 CPU
Graphics Software said:Driver Packaging Version 8.961-120405a-137134C-ATI
Catalyst Version 12.4
Provider AMD.
2D Driver Version 6.14.10.7261
2D Driver File Path System/CurrentControlSet/Control/Video/{5BF58CFF-4A14-4265-9763-D30B77FC7B82}/0000
Direct3D Version 6.14.10.0903
OpenGL Version 6.14.10.11631
Catalyst Control Center Version 2012.0405.2154.37503
Graphics Hardware said:Primary Adapter
Graphics Card Manufacturer Powered by AMD
Graphics Chipset ATI Radeon HD 4870 X2
Device ID 9441
Vendor 1002
Subsystem ID E89A
Subsystem Vendor ID 174B
Graphics Bus Capability PCI Express 2.0
Maximum Bus Setting PCI Express 2.0 x16
BIOS Version 011.016.000.025
BIOS Part Number 113-AAE89Q-X101
BIOS Date 2008/12/11
Memory Size 1024 MB
Memory Type GDDR5
Core Clock in MHz 750 MHz
Memory Clock in MHz 900 MHz
Total Memory Bandwidth in GByte/s 115.2 GByte/s
