Need help with determining this cards...
Discussion in 'nVidia Flavor' started by Markus54, Nov 14, 2017.
  1. Markus54
    Markus54 n00bie
    5
    Oct 29, 2017
    I need help to find out which PCI size this card is. It is an NVidia GT640. It goes into an HP 700-330qe. I want to upgrade my video but I don't remember what kind of PCI it is or PCIe
    Thanks
  2. ssnyder28
    ssnyder28 2[H]4U
    3,244
    May 9, 2012
    it has to be pcie, pcie x16 to be exact
    Armenius likes this.
  3. hlfbkd420
    hlfbkd420 Limp Gawd
    245
    Jun 16, 2017
    Clearly it's AGP :p
    J/K
    Looks to be PCI-E.
  4. _l_
    _l_ I Am A Cock
    1,178
    Nov 27, 2016
    is that the forerunner to todays GPU blower ?
  5. pendragon1
    pendragon1 [H]ardForum Junkie
    12,444
    Oct 7, 2000
    yeah that's pcie and you can put in whatever you want as long as the psu supports it. not sure if it has pcie power and its only 450-500w...
    if you upgrade the psu you can put whatever you want in there as the slot is pcie 3 x16 and you have the horse power.
    https://support.hp.com/ca-en/document/c04345134#AbT2
  6. Markus54
    Markus54 n00bie
    5
    Oct 29, 2017
    OK, But I'm looking for a 1x or 16x response. Something along those lines. I want to get a newer card with more horsepower. It looks like it is a 16x card.
  7. Fixall
    Fixall [H]ard|Gawd
    1,385
    May 17, 2011
    That's a 16 lane PCI-E slot you have on your motherboard. Any PCI-E GPU that's runs at 16x or less will work in there. Considering you have a 4770k or 4790 in there, you can run any modern GPU your power supply is able to handle. I'm not sure what brand the power supply your PC came with, but if it's high quality, 500w PSU (a little unlikely), you could run something like a 1070/1070ti. Otherwise I'd throw a 1060 (which would be like 4 or 5 tiers ahead of a GT640) in there and call it a day.
  8. pendragon1
    12,444
    Oct 7, 2000
  9. Markus54
    Markus54 n00bie
    5
    Oct 29, 2017
    Thanks for your help guys.
  10. eclypse
    eclypse 2[H]4U
    2,615
    Dec 7, 2003
    Whatever you get be prepared to grab a new power supply 500-750watt to be safe if the one you have is aged. Random black screens and restarts and shut downs is what can happen if the power supply is old and warn to where it's not putting out it's rated watts anymore.
    If it's a smaller case with not great air flow do with a blower style founders edition card thst will pump the heat out the back but will be louder then a dual/triple fan card. If it don't have multiple exhaust fans in thst case it will cook the card in the 80-90c range.
