HAL_404
- Dec 16, 2018
Can I build a decent 5.1 system with used stuff for $500 or less? Any recommendations on components (make / model) ?
forgot aboot that since i use optical.HDMI emulator plug, so Windows sees A/V receiver as a standalone monitor.
ashmelev75 , Does that mean that you are running a separate HDMI cable out of your video card to the receiver just for audio? I've only ever used pass through in the past. No issues with audio being out of sync?
I've been wanting to jump back into the 5.1 speaker game again as well but have been hesitant because of potential difficulties with HDMI 2.1 and 4k 120Hz once the next gen video cards are out. I'm not sure what the outputs will look like on a 3080ti, but maybe HDMI 2.1 also means more than a single HDMI output(my 2080ti only has 1 HDMI and 3 DP). Perhaps I could just run a second cable to the receiver for audio and not have to worry about pass through specs. I have also seen the DP to HDMI adapters that say they'll pass 7.1 uncompressed audio.
I'm blind. Coffee is clouding my vision. Just saw this part.thanks for all the good input. Checked out ashmelev75's receiver link and saw this one on eBay for cheap so I went for it:
Yamaha RX-V463
got it for $100 shipped and includes 2 Insignia bookshelf speakers (I'm not an audiophile and so, they should be ok for now)
also just went with Micca center and two bookshelves for $100 from Amazon (free Prime Trial was offered )
will post how it goes once I test it out (says May 14 for Amazon order)
ok, here's the rundown on what I bought. Worked out great, sounds fantastic. Bought everything for under $500 (shipped)
