System-
Asus Sli Deluxe
2GB SAMSUNG (GENERIC) RAM 3-3-3-8 2x1GB
AMD 3700+ SD KAB2E 0543FPAW
7800GTX
550W HEC PSU (Good PSU).
Cooling- Stock cooler but temps did not go high.
I bought the San Diego off a member on another forum, hes a great guy and is very respected.He said that the CPU was only used for 2-3hours. The guy claimed 2.8ghz with 1.5V, i was thinking great! 2.6ghz at 1.4 would be ok.
So I run Prime95 at 1.4V- 2.64GHZ. I get a "FATAL ERROR" and it also said "HARDWARE FAILIURE" , so then I restarted a gently pushed up the voltage,
same error,
again, same error
I got to 1.45V and it still was not stable.
I have a scythe ninja opposite me but man its hard to install, I already tried and failed. the thing that scared me is that I pushed quite hard down on the processor. Is that something to worry about?
Heres my settings-
Divider 333mhz
FSB- 240
Multi 11x
Voltage 1.45V
HTT multiplyer- 4x
Im currently running PRIME 95 at stock everything to check whether everything is stable. How long shall I leave it on for?
What should I do? Why will it not overclock?
Thanks.
Asus Sli Deluxe
7800GTX
same error,
again, same error
Heres my settings-
Divider 333mhz
FSB- 240
Multi 11x
Voltage 1.45V
HTT multiplyer- 4x
Thanks.
