onetouch40
- May 13, 2002
I recently bought a thinkpad laptop from a local seller but there's a PW protected on there.IS there anyway I could bypass the PW? Thanx
BillLeeLee said:If it was a local seller why don't you try asking them first?
lol may be..may be not...Well I got tons of legimate reasons to throw out but no point cuz u guys woudnt believe me anyway.Vesentac said:Probably because the item is "hot".
Gila724 said:IBMs are infamous for having very hard to remove supervisor passwords. If you were to ask on the forum at thinkpads.com, your thread would be quickly locked and you would be ridiculed.
It looks like the same thing is going to happen here unless you have a legitimate reason for it coming into your ownership with a supervisor password
edit: unless you bought it from the seller cheap BECAUSE it had the bios password thinking it would be easy to remove, even then, haha.
First thing to check is whether the hard drive has a password, then either do the stuff listed on that site mentioned above or check out ebay for a new motherboard.
